ok, maybe a little insight to how i make the knife handle might help.
taking a pattern or making what i can from what stock i have generally starts with pencil. then to the drill press, and off to the scrollsaw or bandsaw, depending on style and how elaborate it is removing as much waste as i can then off to the drill press to the dumb sander where the shape is almost finished with abrasives...
the blade fit is tested, handle is plastic/paper covered, and taped off, then epoxy into the snug fitting socket the blade is attached. 24 hours later, i return to the cleanup of the tape-epoxy mess and finish sand the handle with several grits of abrasives on sand o flex to level and flatten surface, then tack cloth, and dip in deft, 30 minuets later the deft skim coat dries to touch, but i leave it 24 hours to dry, returning i take the handle to the sand o flex and again smooth sand the handle so the whole surface will grip the next coat of deft, (in this step i sand to wood to remove some imperfections) tack cloth or blow with compressor and dip in deft again, hanging from the blade to drip and dry,
24 hrs later, i hand sand if needed to remove embedded dust or bugs, and dip one final coat.
i have refrained from using sealers due to the sticky problem before mentioned in previous post, thinking i was using incomparable chemical compositions, ive had results of sticky finish, finish fogging to white "filling pores", and now blisters...
wondering if i need to build a vacume chamber, and submerge the knife in deft while pulling vaccume should pull out the air in the wood.
BRIAN D: i think im getting some better understanding. with the blisters, i might dip first coat almost completely leaving some raw wood to vent pressure, then dip final coat complete
brianh: ill get some compatible thinner and cut the deft by 25-50% and see what happens. as i understand, after second coat of deft the pores should be sealed..
squbrigg' : i have tested them all on basswood as i made them, the straight razor knives all carve like butter....
they all cut great, as can be proven by DNA testing, as i cut myself at least once on each blade
makinchips: i agree, anything in volume expands under temperature increase, and air/water increases almost 2:1 ratio to solids given the same conditions.
its terrible to get so old you cant remember simple physics... C.R.S. syndrome i guess..
I guess, another option is to dip the handle in the deft after it cools down in the evening,
BUT, i have always heard from ole experienced painters,
1. never paint after 4:00pm
2 never paint when its raining or foggy.
why? i could never get a logical answer..... i figured maybe job security,
thanks for the comments it gives me other avenues..
