  #21
Old 02-25-2008, 12:25 PM
arnie's Avatar
arnie
Send a message via Yahoo to arnie
Default Re: Sanding the Low Spots? Help!
Vic, I agree with bandiad. I also had a lot of trouble when I was a beginning carver with rough areas and fuzzies ( by the way I have recently promoted myself from the beginning ranks to idiot carver). Really small areas try rolling some fine sandpaper into a long cone and sand with the small end,be inventive Ive glued sandpaper on hacksaw blades and used the teeth of hacksaw blades as mini scrapers. However the thing to strive for as you carve is to watch for the causes of the stray cuts and eliminate them. I had the darnedest time learning to watch my entire length of my knife blade as I used it,it's awfully easy to make two cuts when you only wanted one. Arnie
Old 02-25-2008, 01:14 PM
Merle Rice's Avatar
Merle Rice
Hi Vic, You didn't say if you had a Dremel Tool, but if you do I find that 3M makes small Bristle Disks that you use with a Dremel tool. I find that they do a very good job. I think that will give you the finish that you are looking for. The tip for using is to run it as slow as the Tool will go. If you run it fast it will not last very long. Yes to your . Watco Wax, Acrylic paint, Polyu, then Feed-n-Wax. Merle
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f53/sanding-low-spots-help-16219/
Woodcarving Illustrated Message Board This thread Refback 02-21-2008 06:47 PM
I need help with sanding Alice in Wonderland Power Carving 19 03-29-2008 12:46 AM
poly over gummy spots jartzh Wood Finishing and Painting 0 09-22-2007 09:59 AM
Sanding bbeery General Wood Carving 11 02-15-2007 12:37 PM
need sanding help barbs777 Wood Carving for Beginners 11 05-03-2006 11:49 AM
Mold spots on Cypress knees GeorgiaCarver Carving Wood & Materials 9 01-24-2006 08:33 PM
