Old 02-21-2006, 06:31 PM
Kenny_S's Avatar
Default problems with finishing a relief rose
I finished carving a relief rose and put a Deft semi-gloss finished on it this morning. Thought it was dried but when I was using a brown paper sack to knock down the rough edges the semi=gloss finish start coming off. I either have a piece that has not completely dried or cured or bad semi gloss. I am going to wait another 24 hours befor I do anything with it. First time for me. Will have some pictures later.
Looking at the weather meters, one says low humidity and the other one says dry. I wonder if the stain was dry, Again, felt dry to the touch.
edited- Well, I couldn't keep my mits off of it. Lesson learned. Quit why you are ahead. Yep, I made it worse.. Not only did I mess it up more, while working on it I broke one of the three leaves off. Stupid mistake for sure but lesson learned again, don't put to much pressure on a delicate thin piece of wood. Oh well, I will jus carve another rose for my Mother in law. Maybe!
Old 02-22-2006, 03:03 PM
Kenny_S's Avatar
Default Re: problems with finishing a relief rose
I have basicly answered my question to my finishing problem. " Moisture " The carving drawed dampness from the staining to the finishing.
Well, I think that is the problem. Letting it set now to see if it will dry out more.
Old 02-22-2006, 06:05 PM
Deft is laquer. It dries fast to the touch. It doesn't harden or "cure" for a week or more. I've been using it since the .....oh never mind. A long time
Let it "cure" a little more next time. BTW, I like 0000 steel wool to smooth it.
my2cents
Old 02-22-2006, 07:14 PM
Kenny_S's Avatar
Thanks Makenchips. I have also use Deft ever since I can remember. Well close to it. It wasn't the finish but dampness before I applied it. Even where I had let it set for 48 hrs, It did the same thing. Never had a problem with it before but this time, the piece set out in the garage for a couple of days before I put the finish on.
I appreciate your input.
Thanks
Old 02-22-2006, 08:27 PM
Kenny,
Did you use an oil stain or water base?
Old 02-23-2006, 01:14 PM
Kenny_S's Avatar
Water based stain! have used it countless of times and same finishing. But this one was out in the garage/shop for a couple of days before I started the staining/painting.
Now , It has been inside the house for 24 hours and I have sanded down and started over on the rose bud.
Old 02-23-2006, 03:17 PM
Thanks,
I've always used the minwax base stains......sounds like i'll stay with em too.
A Rose is a Rose by any other name Doug Ridley New Projects and Works in Progress (WIP) 10 11-01-2006 11:23 PM
Tnaga Nut Rose Reni B Carving Wood & Materials 8 05-03-2006 10:38 PM
Rose Kenny_S General Wood Carving 19 02-27-2006 01:41 PM
Golfball Rose MelNM New Projects and Works in Progress (WIP) 9 02-02-2006 09:13 AM
ROSE Pattern importedpork General Wood Carving 15 01-30-2006 10:34 PM
