Old 10-04-2003, 12:48 PM
jordan
Guest
Posts: n/a
Default Minwax Antique Oil
Does anyone know what to use to thin the antique oil? I poured mine into a mason jar for ease of use and it has started to thicken and I threw away the can and have not been able to fine one close by to check out the instructions, thanks.
Old 10-04-2003, 06:07 PM
Dale_O
Guest
Posts: n/a
Default Re: Minwax Antique Oil
Jordan
Most solvent based products can be thinned with Mineral Spirits. I haven't used it for a while but Antique Oil is basicly a thinned varnish that may have some Tung oil in it. You are better off and cheaper off mixing your own blend. A common ratio is 1/3 Mineral Spirits, 1/3 Varnish, 1/3 Linseed or Tung oil.
I tend to use Turpinetine instead of Mineral Spirits because I like the smell better. But for your need's stick with Mineral Spirits to thin the Antique Oil.
Hope this Helps
One more thing the Antique oil may have some bee's wax also. You can also add bee's to suit your needs in the above mixture I mentioned.
Dale
Old 10-05-2003, 10:06 PM
Mr._Carvit
Guest
Posts: n/a
The Minwax Antique Oil Finish is composed of 34% Linseed Alkyd Resin and 66% Petrolium Thinners. You can use Mineral Spirits or Paint thinner.
aquiring antique Vaccume filter Thomp Woodcarving Tools, Technology & Sharpening 11 08-07-2006 10:40 AM
Antique tools deweyrf91 Woodcarving Tools, Technology & Sharpening 8 05-05-2006 07:14 AM
MinWax Clear finish & Polyurethene problem BasketballJones General Wood Carving 3 11-20-2005 09:38 AM
Revitilizing antique Wood Cut_Fingers Carving Wood & Materials 7 09-28-2004 05:05 PM
antique techniques macktruck General Wood Carving 11 06-18-2004 06:42 PM
