Old 08-23-2006, 11:33 PM
kcwaterguy's Avatar
Major Beginner
Send a message via Yahoo to kcwaterguy
Default Final prep and painting my Santa
Okay all... my first piece in the round is Goody's Santa rough out... I think I did "ok" and am ready to paint.... that pine was rough on my newness and I could not get it to "smooth" out with the knife. Is it okay to sand it smooth now before painting? Also, when I go to paint... just do it on the raw surface... or is there any prep?
Thanks,
Sean
Gouge Chip Carving since Feb 2006
My online album
Old 08-24-2006, 08:01 AM
Kenny_S's Avatar
Senior Moment
Default Re: Final prep and painting my Santa
It is your piece, if you want to sand it, sand it. Pine will soak up the paint. You can either prep it with a coat or two of Deft Matte spray or Gesso it and then paint it. If you do either, use a wadded up piece of brwon paper sack to smooth it daown and then paint it.
Pictures please!
God Bless
Kenny
Old 08-24-2006, 11:40 AM
OK I was going to send this in as a tip to BobD (you paying attention Bob? lol, ohhh Bob, can you hear me above the chainsaw ringing in your ears ha ha) any way, I have been using miniwax sanding sealer and really don't care much for it for carvings, its very rough (I know, SAND)ha ha, but it also is a little difficult as it doesn't want to take acrylic paint readily, it will but not the way I like it.......so..I had at the same time I bought the sanding sealer bought a small can of prestain sealer.....that works great! the basswood was smoother when the prestain sealer dried that it was before I applied it, the paint went on exceptionally well and I can either put the paint on opaque or as a thin wash.....I am converting to minwax prestain sealer....... Dave
Old 08-24-2006, 03:47 PM
Just Carving's Avatar
WhittleBear Carver
Dave,
Are you using the Minwax® Water-Based Pre-Stain Wood Conditioner--which is for water-based wood stains?
http://www.minwax.com/products/woodp...r-prestain.cfm
Because they also make the Minwax® Pre-Stain Wood Conditioner which is for oil based stains.
http://www.minwax.com/products/woodprep/prestain.cfm
I just want to double-check. I am finally getting to the point where I will be painting some carvings so I have to brush up on what I need to know for using acrylic paints, etc.
Thanks.
Old 08-27-2006, 11:53 AM
Donna_T's Avatar
Depending on the final look you want, there's another train of thought on painting with water-based paints...
Once your carving is finished, washed to get the any dirt and/or oil it's gotten off your hands, just go ahead an paint it without any kind of sealer. Of course, I like using thinned water-based paints and building coats of it to get the look I want. Lately, however, I especially like getting the carving wet with water first so that the dry wood doesn't absorb all the water from your paint so quickly. Once it's all painted and dried, I like to rub it down with brown bag technique--or lightly once-over it with a soft Scotchbrite pad, before applying the final finish.
My final finishes run the gammut from a spray of Deft or lacquer, to wax, to another rubbing with the ole brown bag and then waxing it.
I'm interested in the pre-stain treatment...must try that sometime soon.
If I'm "antiquing" a painted carving, I usually put a spritz of lacquer over the face to keep it from getting to dark from the antiquing process.
Donna T
Old 08-27-2006, 02:41 PM
Originally Posted by Just Carving
Dave,
Thanks.
The one I am using is not the waterbased....didn't even know they had water based! lol, might try it when this can is empty...only reason would be so I could swish the brush in water to clean it h aha.....this oil base works great, I like it a lot. Cowboy
final pirate pic aarrgghhh DADDIO New Projects and Works in Progress (WIP) 11 02-09-2007 08:53 AM
Giant Santa and the woodspririt ready for painting Colin-Partridge Holiday 7 06-18-2006 11:45 AM
Question re: Painting Prep Work jillsy Wood Carving for Beginners 13 04-26-2006 07:50 PM
Painting Santa Chahlie General Wood Carving 4 06-16-2004 11:50 AM
Painting a Santa Colin-Partridge Holiday 8 03-10-2004 10:07 PM
