Re: Can different finishes affect the final color of wood? There are different types of Mahagony some are darker then others,so it may be thet yours is the darker kind??? I have seen some they are almost black/red, you still can use some W,B,P on top of Wtco only after it has cured well,no more smell.
I use water bourne Poly on all my light colored wood, I also have used BLO on it before and I wipe it off after 30 minutes and then I let it sit until there is no more smell, I just finished a red Cedar Bowl and it turned out perfect , the red really shows up by using the above method.
I hope this helps
Alice |
