Old 01-20-2009, 03:01 PM
Default Using styrofoam to hold gouges
Is there any problem in using a block of styrofoam to stick gouges in and using the foam as a tool holder?
Harris
Old 01-20-2009, 04:30 PM
Mitchell's Avatar
Default Re: Using styrofoam to hold gouges
It would be for me.............
the sound of anything rubbing on styrofoam is like fingernails on a chalkboard.
To answer your question - no, I don't think it would affect your tools in any negative manner.
Old 01-20-2009, 06:29 PM
Sounds reasonable to me too! I think the blue construction type stuff is stiffer and may hold better.
Merryl
View my carvings at: www.highlandwoodcarver.ca
Old 01-20-2009, 07:52 PM
Mark N. Akers's Avatar
Harris:
I have a box I tend to teach from,as its so hard to carry around my normal tool box,here's what I use its very good for tools.Minicell Foam its what they repair Kayak's with.
Old 01-21-2009, 06:51 AM
bbeery's Avatar
I buy those cheap foam cylinders (3" x 4' +/-) they sell in the Dollar stores for kids swimming pool flotation devices. Just cut to your specifications.
Old 01-22-2009, 11:08 PM
morganwoodcarver's Avatar
This is what i use to carry my gouges around in, I took a heavy cardboard tube and drilled holes in it for all my palm tools, then i taped up one end and filled it full of Great Stuff expanding foam and it made a solid chunk inside the tube, the tools fit nicely in the foam and they are protected.
Old 01-23-2009, 10:23 AM
DManning's Avatar
The only "down-side" I wonder about is keeping out moisture. I made some blade covers using the compound that dentists use for making molds. It worked o.k. when the humidity was down, but, being a plastic, it retained water when the humidity was high. If styrafoam holds water like that you'd better plan on oiling edges more often.
Old 03-26-2009, 03:19 AM
rbloch66's Avatar
Robert Bloch
I glued a few pieces of styrofoam together with wood glue, and didn't let the glue dry completely. I stuck my palm tools in. In a matter of less than a day my tools showed some pretty heavy duty signs of rusting.
Needless to say I spent the next couple of hours using fine grit wet/dry paper to bring the shine back up, and also had to give them a honing.
A hard lesson never to be forgotten.
Old 03-26-2009, 09:32 AM
TreeWizard's Avatar
I like to use wine corks. For various reasons.
Paul.
Old 03-27-2009, 02:09 AM
santacarver's Avatar
I have been using a big block of styrofoam for years to hold all my carving knives and I've never had a problem. I would recommend it.
Bench hold Dennis Taylor Wood Carving for Beginners 4 09-16-2007 11:02 PM
Hold on Otas, It hurts when you fall. Arnold-Smith Caricature Carving 11 08-20-2007 07:34 AM
What do you use to hold your carving?? Blake Lunsford General Wood Carving 18 10-31-2005 09:40 AM
will styrofoam dull knives Jaysonmol Wood Carving for Beginners 2 10-27-2005 08:11 PM
How to hold the wood while carving Brad Wood Carving for Beginners 20 11-03-2003 05:41 PM
