| Found the Fox?
11-29-2007, 11:01 AM
| | slow speed elec. motor I would still like to find a slow speed motor for an arbor I have! Would like a 500rpm to 800rpm.....want to put a hard felt wheel on one side and a paper wheel on the other.....anyone know of anywhere to get one? small size is fine too! |
11-29-2007, 11:10 AM
| | Re: slow speed elec. motor Hi HO,
Have you looked into a DC motor? My husband put one on a grinder for me so I could vary the speed I used. And it's on a foot control so I have both hands free. Seems to be the cats meow..... |
11-29-2007, 11:17 AM
|  | Senior Member | | Join Date: Jan 2006 Location: Delaware, Ohio
| | Re: slow speed elec. motor Hey Dave, try an pld floor scrubber motor. Go to a sweeper store and see if they have any out back. I think these motors are real slow. Tom H |
11-29-2007, 11:23 AM
| | Re: slow speed elec. motor check out ac/refrigeration repair shop's, there should be a good supply of blower motors,
small window a/c units have 110 motors most are 3 speed.
if the compressor goes out most folks just toss the whole unit
im not sure if there is standard speeds through the industry or if i just lucked up. mine is 800 on low speed, it wont pull a hard load, but just enough to hone... |
11-29-2007, 11:57 AM
|  | Teddy bear carver | | Join Date: Nov 2004 Location: Edison, NJ
| | Re: slow speed elec. motor Hi Dave.
I know what you want to do, but until you can find the motor, can you jerry-rig an arbor to go in a hand drill clamped down? I think the rpm would range from 550 on up. You can probably vary a variable speed to what you need. Just a thought....
Bob L |
11-29-2007, 01:00 PM
|  | Member | | Join Date: Oct 2007 Location: Wesley Chapel Fl.
| | Re: slow speed elec. motor Dave, have you checked Harbor Freight, they have a couple variable speed grinders. I think one is 3 inch and the other 6 inch ( not sure ). Can't beat their prices, don't know about the quality. Dave |
11-29-2007, 06:50 PM
| | Re: slow speed elec. motor Just to follow up on the DC motor thing..... I looked at the brand on the grinder my husband set up for me and it is a K-Line brand. I didn't google it but you might check them out. It has a built in variable speed which is turned all the way up since it is plugged into a variable speed footpedal.... I have a felt wheel and a 3M wheel on it. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -4. The time now is 11:19 PM. | |
