I have a tool that I have had to sharpen, but I have hit a snag. The tool feels sharp and cuts with the grain good, but when I start to cut against the grain, it doesn't want to cut. What would cause this?
how about the bevel? I sharpen flat from back of blade to edge...
none of my tools like to cut "against the grain". if the tool is sharp it should cut "with the grain" & "across the grain". they tend to dig in "with the grain" and a breakout or a serious accident is about to happen. ie...cutting yourself!!!
__________________ Keep carvin' & God bless you, Terry John 3:17 <>< http://www.picturetrail.com/terryvance my WCI gallery |
Hi-Ho's probably given you your answer. If your bevel is rounded it will try to dig in instead of slicing through.
I guess what I ment was it has truble going across the grain. It might be that I am rounding it. I'll try to sharpen it again.
The edge is not sharp, most likely you have a wire edge or incomplete sharp edge. A sharp rounded (dubbed) edge will easily cut across grain. Get a magnifier eye loop and check the edge under a lamp,,,this will show very easily where the problem is on your sharpening adventure.] Cutting paper or shaving your arm is not a good indication of a sharp edge,,,,your test of cutting across grain is one of the best methods of testing a wood carving tool. Regards, FK |
So perhaps you have both a "dubbed" and "dull" blade???
either not enough bevel or tool isn't sharpen enough. When I sharpen, and I am not that great at it, I test on the end graon of a block. If it is smooth and shinny, then sharpe enough but if there are little tears a long with smooth cut then it needs more time spent on sharpening.
I have a question to add to my other. I only have up to a Hard arkansas stone, and was wondering if a black hard would get my tools any sharper.
If you are using only stones for sharpening, you probably need a leather strop for final honing.
| Bandsaw problems | James A | Woodcarving Tools, Technology & Sharpening | 49 | 07-18-2008 02:13 PM |
| problems | Jace Burnette | Off Topic | 1 | 02-01-2007 09:33 AM |
| problems with smileys | rales | Message Board FAQ, Suggestions and Feedback | 5 | 05-20-2005 05:20 PM |
| Picturetrail problems | icarve2003 | General Wood Carving | 3 | 05-05-2003 08:27 PM |
