Some time back we had quite a discussion about the sharpening machine that Sears sells. I know this is not the place for commercials, but for any of you that would like to pick one up, they are on sale at Sears for $17.xx. (Slow moving wheel that goes through water.)
Thanks you for the info. Ken
Commercial or not, the machine works fairly well. I bought one (not on sale!) and use it to shape the blades of the carving knives I make. I strongly recommend you follow the directions to flush it out after each use. The filings will accumulate, rust together and lock the wheel in place if you don't. Don't ask how I know this. :
__________________ Captain Bandaid All the world is a stage and some of us are acting poorly. |
Thanks Capt for that information. I find the university of hard knock gives better lessons than any other university and it is more costly. So we tend to learn from our own and other's mistake. I take it you still have to strop the blade. For someone to make a device to automaticly strop the knife after sharpening. A device other than our selves I mean.
Kenny, the wheel on the grinder is quite coarse. I shape the blade on the wheel, then do the final sharpening on a soft Arkansas stone or an 800 grit waterstone. Yes, you still have to strop it but if you use a 4000 grit waterstone after the Arkansas or 800 grit stone, you may not have to strop. I have found that power stropping is a waste of time. I can do it faster by hand.
Personally I use a TORMEK sharpening system. After using it, all the other systems seem inferior. Between the 2 grit grinding wheel and the power strop, I can put a top notch edge on practically anything ( I am having a problem sharpening my drawknife, oh well nothings perfect...). All in under 10 minutes!
Munchkin, well, you have the best of the best sharpening systems and I am not surprised you can do it in 10 minutes. I just don't need to go to a grinding wheel enough to justify the $500-600 for the unit. I can re-sharpen a totally dull blade using my waterstones and a hand strop in about 15 minutes. I have about $25 invested in my poorman's system. My only concern about using a coarse grinding wheel to sharpen my tools is that the stone is wearing away my tool! The more you sharpen, the faster your tool disappears. Frequent stropping and occasional stoning will keep your tools around a long time.
I'm a meat processor, and butchers' knives need to be sharp. Thats why I have the machine. I personally have it because those butchers have destroyed all the machines they've used in the past. Don't ask me how. Has anyone tried to use a steel on carving tools. I'll often use one on my other knives, but it hasn't worked very well on my tools. |
I will say that even though the stone feels somewhat rough, it puts on a reasonably smooth edge and works very well once the 'stroppable edge' wears off a tool. However, I certainly don't use mine very often. PS: My wife loves it too, for obvious reasons. Even the edge on our countertops is sharp. |
How about a power strop? Does anybody use them and are they worth the money? ??? Chris
__________________ Safety first |
| Ultimate Sharpening Machine...good or bad buy? | Elmer | Woodcarving Tools, Technology & Sharpening | 20 | 02-24-2007 04:09 PM |
| Sump Pump sharpening machine? | R-OLDS | Woodcarving Tools, Technology & Sharpening | 9 | 10-09-2006 11:49 PM |
| Ultimate Sharpening Machine...good or bad buy? | Elmer | General Wood Carving | 1 | 10-08-2005 12:21 PM |
| Ultimate Sharpening Machine | kettlekarver | General Wood Carving | 6 | 09-30-2004 11:17 AM |
| Inexpensive Sharpening Machine | woodenleg | Woodcarving Tools, Technology & Sharpening | 25 | 02-26-2003 05:07 PM |
