Re: Power Strop? Ron, You are suppose to set up the power hone backwards to a grinder, and you work off the top so if your blade hangs, and gets cought it throws away from you, with speed control of different size pullies, 2 speed or veriable speed motor, you can change belt like drillpress or lathe. and slow the rpm down not as slow as a hand hone but slower than a bench grinder. you keep it slow to keep heat from building up as well.. |
