Originally Posted by vacaricature carver Dave,
Can you also attach these to a grinder? I definitely need some help with my sharpening. I just can't get a good edge on a knife by doing it by hand.
Thanks!
Blake |
I've only used them on a drill press but the same carving company mentioned above also sells a relatively inexpensive metal drill stand that you can clamp to a work bench then mount any small portable drill.
I would imagine that the Powerstrop might be too small for a standard grinder. My Powerstrop measures only 3 1/2" from one side to the other and it has a reccomended speed of 600-800 rpm which is easy to adjust on my drill press.
It seems like I've seen a sharpening device that resembles a a standard bench grinder but I can't remember where AND whether you could buy the leather wheels separately. As for me, I like the Powerstrop option since I already have a drill press, but I've also used it just fine in a small portable drill by just placing the drill in my bench vise.
I can keep most of my carving blades razor sharp with only the minimum maintenance of my
beloved 900 grit "extra-fine" Arkansas stone (that's one expensive stone, by the way!) and a quick polishing with my Powerstrop. Most of the time the blade only needs the Powerstrop and I usually give them only what they need after approximately every 20 minutes of carving time per blade.
Good luck!
Bye the way I notice that you're from Abingdon which is close to Damascus and the Grayson Highlands, some of my favorite outdoor areas! I've done a LOT of moutain biking on the Virginia Creeper Trail and I always try to make it to Trail Day's in Damascus each May. Great country!!
