Old 07-24-2008, 07:58 PM
oldbearx2's Avatar
Default Power sharpener
Need some advice. I am in the process of making my own power sharpening system. I would like to pattern it after a Burke system. I have all the required parts, but am struggling with the actual sharpening wheels. First I planned on turning wooden wheels on the lathe, about 6 inches in diameter, with profiles for the v tools and gouges. I would like to be able to just apply the sharpening compund to the wooden wheel, but what type of wood is best. I have basswood, soft maple, hard maple, cherry and walnut. Is softer better or the harder stuff. Also what about the felt wheels which is better hard or soft. I will turn one wheel and glue leather to it, for the flat tools and knives, and have one with emory for reshaping edges. I have started making my own knives and plan on using this to get the blades in carving condition. Any help will be greatly appreciated.
Have fun, carve
Harold
Old 07-24-2008, 08:49 PM
Eddy Smiles's Avatar
木彫る
Default Re: Power sharpener
Harold... I don't know much about power sharpening, myself being a firm believer in the old fashion method. However, I did break down and install a honing wheel on my bench grinder. When I did my research I was advised against going with soft cloth or felt wheels as they will round off your edges. I ended up cutting out a 6" diameter wheel in a piece of empress wood which is softer than basswood but harder than balsa. There were a few flat spots to begin with but after a few uses the wheel trued itself and for the little that I use it I'm pretty satisfied with it's performance.
Old 07-24-2008, 11:52 PM
The problem I always have with wooden wheels is, they're round when you turn them but get out of round when they dry out (from the heat caused by friction in use). Especially our local wild cherry, which turns into a Pringle shape.
Then I started making them out of MDF. No grain, no uneven drying, just porous enough to hold the compound. The ideal honing wheel material. Be sure to sink the drive spur good and deep, or you'll send them rolling across your shop like I did. It's amazing how far they'll roll coming off the lathe at 1725...
Parker
Last edited by cats pa : 07-24-2008 at 11:54 PM. Reason: to add somethin' I forgot.
Old 07-25-2008, 11:15 AM
Best wood to use in my opinion is the pressed wood...much more stable that natural wood. use a metal hub or bearing in the center so it doesn't beat out with time, after that is in, put on a lathe and true it up .....then put a band of leather on the outside....makes a good strop wheel.
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f52/power-sharpener-18393/
Woodcarving Illustrated Message Board This thread Refback 07-24-2008 10:10 PM
Ultimate Power Sharpener from Chipping Away George Will Woodcarving Tools, Technology & Sharpening 37 09-05-2008 07:06 PM
Which power sharpener is the best? jstive Woodcarving Tools, Technology & Sharpening 20 07-28-2008 05:19 PM
3M sharpener hruukki Woodcarving Tools, Technology & Sharpening 7 05-30-2008 05:24 PM
Jet Wet Sharpener barbs Woodcarving Tools, Technology & Sharpening 13 03-26-2008 03:53 PM
Oar Sharpener torpidhummer Woodcarving Tools, Technology & Sharpening 7 12-17-2007 10:37 PM
