Re: I NEED more tools...but its just a mini need. Mischief, I can sure help you stay "budget" minded and this is a real tip and not a joke. If you can find an old umbrella, the ribs are made of good spring steel. Cut the ribs into pieces about 3 inches long and use a little propane cylinder torch to heat just one end back about 1/2" until it is just begining to show a color change and quench it quickly in transmission/powersteering fluid. Drill a hole and epoxy the rib into a 1/2" or 5/8" dowel rod with the heat treated end out. Sharpen the cutting edge and you should have a great mini-veiner. Also different umbrellas used different size ribs and you can make several sizes. Only other recommendation is to only use worn out and discarded umbrellas to keep outta trouble!!!
Norb |
