Good Morning All, I'm a kind of on again off again type of beginner, yeah I know I should be more of a on again....that being said I have inherited a delta 16" 28-540 bandsaw , with the helpful post and replies I have found the manual, but when I try to cut a block of basswood 3" thick the blade gets stuck in the wood... please help - what am I doing wrong Cheers, Elaine |
Well, not being there, it's tough to tell. But here's my guesses. You are twisting the block and binding the blade or trying to make too tight a curve. You have a very old blade that has insufficient kerf. Solution to number one is to quit doing what you're doing. Solution to number two is get a new blade - Timberwolf or same high quality a little bit less expensive Olson All-Pro (make sure it's the All-Pro, Olson makes standard blades too).
Hi plain ol Ed great, thankyou -I will try both I am a very newbie at this, I am trying to cut a straight line, and I think that the blade is very old, I inherited this a few years back been afraid to try it out, but nothing ventured nothing gained, |
You also may not have proper tension on the blade. After using the saw, tension needs to be taken off the blade, and then re-tensioned before the next use. Claude |
Hi Elaine: You've gotten some excellent advice so far. I would add that the smaller the blade the tighter the radius you can cut. I cut 3 in. basswood with my 15 in Delta and have no problems with the 1/4 in. blade. Check the blade guides and made sure the clearence is correct. Ol Ed suggests a new blade...I would certainly second that suggestion. It's a good place to start. Also, don't rush the cut, go slow and easy an the saw will respond. By the way, I frequently vacuum the sawdust away from mine. Good Luck Ed |
wonderful , many thanks for the great advice, first thing I'll do is purchase a new blade - Timberwolf - then check tension so slow and easy Elaine |
When you get your blade I would recommend a skip tooth blade. Allows for tighter turns. I have seen the TimberWolf demonstrated and it is a great blade for cutting out carving blanks.
__________________ Keep carvin' & God bless you, Terry John 3:17 <>< http://www.picturetrail.com/terryvance my WCI gallery |
Laine I have had the exact same saw since 1991. The 3 wheel design was not one of Delta's better ideas. I too had problems with cutting straight lines with it. I in fact got so frustrated with it it got pushed off in a corner and forgotten for several years. Eventually I got it out and replaced the tires, put a new quality blade on it and aligned all guides, table etc. It works pretty well! If your stalling the motor I would say get a good blade and you will have good luck. Do check those tires, the originals walked off the wheels constantly. I got new ones and now have no problem. Though I will never say it's the best thing since pockets on a shirt, I will keep it till I wear it out before buying a new saw. |
| Bandsaw | dart | Woodcarving Tools, Technology & Sharpening | 3 | 01-26-2007 08:03 PM |
| New Bandsaw | Tucson Bill | Woodcarving Tools, Technology & Sharpening | 17 | 05-15-2006 07:43 PM |
| Bandsaw help | Ken Stephens | General Wood Carving | 11 | 01-24-2006 02:34 PM |
| Bandsaw. | dart | Woodcarving Tools, Technology & Sharpening | 3 | 12-22-2005 05:25 PM |
| bandsaw? | liverlips | Wood Carving for Beginners | 11 | 11-23-2005 03:29 PM |
