Re: Need Advice several ways Ive seen to make the handles,
you can make 2 slabs and carve out a hollow just big enough to set the blade into and epoxy it all together
or make the handle one piece and drill a series of holes side by side then wobble the bit to join them in one slot(this method breaks a lot of bits)
or make the handle and drill a larger hole and force the blade into the epoxy filled hole , the hole should be at 1/8 less than the blade width so the blade has some wood to be anchored into..when the blade, wrapped in sandpaper, its put in a vice and the handle is hammered over the blade., the epoxy filled hole has a piece of packing tape over it to keep the epoxy inside while its inverted and being hammered on the blade. |
