10-14-2006, 05:01 AM
|  | Senior Member | | Join Date: Nov 2005 Location: Lexington S.C.
| | Re: More Power Sharpeners ??? Brian:
From my search for a sharpening system,I found the Burke system to be the best. |
10-14-2006, 09:59 AM
| | Senior Member | | Join Date: Apr 2005 Location: TN and FL
| | Re: More Power Sharpeners ??? I have the Tormek and love it, but if I'd found the Burke system sooner I might have gone with it. |
10-14-2006, 10:17 AM
| | Re: More Power Sharpeners ??? I have the Burke.....I went for the small rv model....wouldn't advise it, get the larger model. Humm just looked at the pictures, I see they raised the mandrel on the smaller model...that would be ok, mine is way to low and is really not good. |
10-14-2006, 04:27 PM
Here's a picture of my sharpening station,some would tell you that you don't need all this,but I don't know which one I would get rid of. |
10-14-2006, 06:58 PM
|  | Member | | Join Date: Jan 2005
| | Re: More Power Sharpeners ??? Mark which one do you seem to like or use the most
__________________ Brian }><((((*> |
10-14-2006, 07:03 PM
They all have different functions,the Burke on the far left is probably the most used.But the center one is a 3700 rpm floppy wheel,fantastic on v tools and gouges,its for buffing only.And the upright sharpener has a denny's sharpening jig that is great forholding tools at just the right angle.But if I could only pick 1 it would be the Burke system,hope this helps you out. |
10-15-2006, 04:23 AM
| | Re: More Power Sharpeners ??? OK,any opinions on the Ultimate Sharpener. http://www.chippingaway.com/WoodCarv...rSharpener.htm
I did not have this on my first list.
I was able to use a larger version of this sharpener that a knife maker I know has, and I like it. Makes a nice flat grind, but you do have to change the belts, which wasn't any trouble.
Not sure which one yet, but I am only buying one of these bad boys so I need to think, think and re-think my choices. Any info would be a great help.
Thanks Brian
10-15-2006, 04:28 AM
I have one of those styles also,and if you add on the sharpening jig that denny's tools makes it is awsome,but for all around sharpening and buffing I still would go with the burke. |
10-15-2006, 12:24 PM
| | Re: More Power Sharpeners ??? Mark thanks for your input.
I believe I have it down to the two, Burke and The Ultimate Sharpener. I thought that the Ultimate would put a flatter grind on the tool then a wheel which is a constant circumference.
Well, Monday I will go play with a burke then I will make my mind up.
I was able to try a Tormek which I also liked and a JoolTool which I did not.
I wish they were cheaper so I could get them all.
Brian
__________________ Brian }><((((*> | | Thread Tools | | | | Display Modes | Linear Mode |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Power Stropping | whittlin | Wood Carving for Beginners | 25 | 04-11-2004 01:18 PM | | power carving | Guest | Wood Carving for Beginners | 2 | 09-16-2003 07:09 AM | | Power Equipment | Brad_Guibas | Woodcarving Tools, Technology & Sharpening | 9 | 06-10-2003 07:31 AM | | Power carving | Guest | General Wood Carving | 0 | 04-30-2003 04:45 PM | All times are GMT -4. The time now is 01:55 AM. | |
