04-16-2008, 10:55 AM
|  | Member | | Join Date: Aug 2007 Location: Spring Grove, IL
| | Meat cutting band saw to cut wood? Hello everyone, I have a question and that is, can I use a meat cutting band saw to cut wood? I believe I can but I need to know. Thanks Bird carver. |
04-16-2008, 11:44 AM
|  | Senior Member | | Join Date: Jan 2006 Location: Jay, Oklahoma
| | Re: Meat cutting band saw to cut wood? I can't really see why you couldn't. Surely it will accept a different size blade than is normally used for cutting meat. |
04-16-2008, 02:21 PM
|  | Senior Member | | Join Date: Jan 2002
| | Re: Meat cutting band saw to cut wood? I saw a listing for a dual pupose band saw, wood and meat cutting, so it must be possible (Grizzly?). Does it have a sliding table? Mike |
04-16-2008, 02:58 PM
|  | Doug Ridley | | Join Date: Oct 2005 Location: Paducah,Ky.
| | Re: Meat cutting band saw to cut wood? No reason it won't work. You will probably need a different blade.
Doug |
04-16-2008, 03:20 PM
| | Re: Meat cutting band saw to cut wood? I cut up deer and hogs with a wood cutting band saw, I don't see any reason the reverse wouldn't work. Be less of a clean up job than what I do for sure. |
04-16-2008, 04:41 PM
| | Re: Meat cutting band saw to cut wood? Thanks Guy's for your help. I figured to go for a new butcher meat saw with a 9.5 inch max cut, it should work. Mike to answer your  it has a sliding table also. If anyone is interested amazon.com or there is other places you can check on, you can pick one up for $200.00, plus $70.00 for shipping. As you know this is a fraction of what you would pay for a normal band saw. I will let you know how it works out. Thanks again, Bird carver
04-16-2008, 05:19 PM
|  | Moderator | | Join Date: Mar 2007 Location: Breadalbane NB Canada
| | Re: Meat cutting band saw to cut wood? Hi, I bought one of the meat cutting saws with the sliding table, it was guaranteed, (not from amazon) paid a good price, it was a piece of junk. Called the supplier, no way they would do any thing. The meat grinder that was an attachment, severed the shaft to turn the worm. The table was impossible to keep lined up, and even more difficult to replace after cleaning it. I've worked as a meat cutter for several yrs and have never seen a bigger hunk of junk !!!!!!!1 You will more than likely have trouble keeping the blade on if your cutting wood.
Heb: 11:6
04-16-2008, 06:07 PM
| | Re: Meat cutting band saw to cut wood? When I posted earlier I assumed you had the meat saw on hand. NO WAY would I pay $270.00 for a meat saw! You shoud be able to find a decent WW saw for only a little more money. Shop around!
Doug |
04-16-2008, 07:18 PM
| | Re: Meat cutting band saw to cut wood? yep...take a look at the Grizzly G 0555 model ...I think thats the number. 14 in and you can get a 6 inch riser for it. |
04-16-2008, 11:20 PM
|  | senior WCI reader | | Join Date: Feb 2005 Location: Manteca, California
| | Re: Meat cutting band saw to cut wood? I gots one of those G0555 saws ............a really good saw.....not only do I think that its a good saw ....but my neighbor does too.
Jim | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -4. The time now is 04:50 PM. | |
