  #21
Old 02-23-2003, 02:52 PM
clifford_parker
Guest
Posts: n/a
Default Re: Inexpensive Sharpening Machine
correction, I measured and the blades are 5/8' X 6'
Old 02-23-2003, 09:34 PM
millhoused's Avatar
Whittler
The Sears sharpener is great for shaping blades without burning them. After that I go to bench stones or DMT Diamond stones.
For some examples go to http://www.picturetrail.com/millhoused
Carvin'
Don
Old 02-25-2003, 11:34 AM
Bandaid's Avatar
Hi millhoused...what method do you use to cut the large saw blades down to a manageable size prior to shaping? I've got a couple of blades here that I was going to fool around with but don't know quite where to start.
Old 02-25-2003, 04:00 PM
millhoused's Avatar
Whittler
I mark them with a sharpie marker and then use a dremel or foredom flex shaft tool with a cutoff wheel. I cut for a couple of seconds and then quench the blade in water. You can see the water evaporate as the blade heats up. Quench it before it gets too hot and the temper will remain.
I leave a little scrap to grind off while making the bevel.
I will post some pictures when I make the next one.
It looks like I am going to make a set of chip carving knives.
Makin' firewood,
Don
Old 02-25-2003, 04:53 PM
Bandaid's Avatar
Thx. millhoused for sharing the info. I'll look forward to seeing the pic's as I'm sure will others in the gang.
Old 02-26-2003, 06:07 PM
clifford_parker
Guest
Posts: n/a
Dons knives are very nice. He posted the url for another group/list and after seeing them I spent an hour reshaping, sanding, and staining the handle on the detail knife I made in September.
Good whittlin, Cliff
Charles City, Iowa
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f52/inexpensive-sharpening-machine-3983/
Woodcarving Tools, Technology & Sharpening [Archive] - Page 12 - Woodcarving Illustrated Message Board This thread Refback 12-21-2007 07:54 AM
Ultimate Sharpening Machine...good or bad buy? Elmer Woodcarving Tools, Technology & Sharpening 20 02-24-2007 05:09 PM
Sump Pump sharpening machine? R-OLDS Woodcarving Tools, Technology & Sharpening 9 10-10-2006 12:49 AM
Ultimate Sharpening Machine...good or bad buy? Elmer General Wood Carving 1 10-08-2005 01:21 PM
Ultimate Sharpening Machine kettlekarver General Wood Carving 6 09-30-2004 12:17 PM
Sears Sharpening Machine woodenleg Woodcarving Tools, Technology & Sharpening 11 06-20-2003 09:05 PM
