Old 01-30-2012, 08:18 PM
Default Re: Good Replacement for my Dremel Tool
Hi, I'm surprised to read that you are able to replace the motor brushes in Dremmels. I quit using them because the models I was using did not allow you to replace the brushes; I went through several and threw them out because of this! I now use a WeCheer, mainly for that reason!
Old 01-31-2012, 12:08 PM
telecarver's Avatar
telecarver
I have used all of the tools suggested above for thousands of hours. My opinion is: While the Foredom is a good quality tool, it is too slow for many operations. Unless you want to invest in a micro motor to augment it, go with the MasterCarver Pro Flexshaft. It is also a good quality tool. I have put mine through many thousands of hours of use with no problems. I own three Foredoms and although they still work fine, they sit in a drawer. The Makita die grinder is great tool but is too large and heavy for any kind of detail work. It is best used for rough out of larger pieces. The Dremel is a good low cost option but the bearing run out makes it marginal for fine detail. The weak point for the Dremel is the switch. I buy the cheapest one speed Dremels and control them with an electronic router speed control from Woodworkers Supply. The router speed control will give you full torque at all speeds, unlike a foot pedal or rheostat variable speed switch. You can also use it with other tools such as a flexshaft tool or angle grinder. It will only work with single speed brush motors. The good news is those are the most inexpensive models and you can still get the variable speed with one unit to control all of your tools. It's one of the most valuable tools I own. Don't buy the one from Harbor Freight. It's a rheostat. Having been there and worked extensively with all of the options, this is my best advice.
Ron Ramsey
http://www.carvedbyramsey.com
Subscribe to my channel, carved by ramsey, for updates on the how-to videos I'm working on about the many aspects of carving doors, mantels, sculptures and signs.
http://www.youtube.com/user/carvedbyramsey?feature=mhee
Like my page on Facebook to get updates and see my latest work in progress as well as updates on classes.
https://www.facebook.com/pages/Ron-R...or/55391262469
Old 01-31-2012, 12:12 PM
telecarver's Avatar
telecarver
The little plastic screws on the outside of all of the Dremels I've had provide access to the brushes. It's a five minute job to replace them
Ron Ramsey
Old 01-31-2012, 01:47 PM
Carvinectimus Prime
Thanks for the question, and the info... Now i can move on from the dremel, which from what i see has its limitations! Very informative indeed!
Sincerely, Bob Vega (Lazy Carver)
All the best,... Rob Vega (Lazy C.)
“Where those who are not artists are trying to close the book, he opens it, to show there are still more pages possible”
Robert Henri 'The Art Spirit'
http://www.woodcarvingillustrated.co...me/lazy-carver
Old 01-31-2012, 09:09 PM
Hi Everyone! Thanks for all your wonderful advice... I'm currently still using Dremels plus one B & D knock-off and have been pleased so far for what I've been doing... Dremels seem to be fine for 'light' carving, but Foreman/Master Carver for heavier work... Until I move on to heavier work, I'll probably stick to my Dremels but thank everyone for your advice as I'm sure at some time I will attempt some heavier carving...ideas are already on my '2doList'...
Again thanks for your wonderful and priceless advice! Safe carving to you all!
Kenn
"Life is like wrestling with a gorilla, you don't stop when you get tired you stop when the gorilla gets tired."
Old 02-01-2012, 12:16 AM
SeaLeveler's Avatar
I have a Harbor Freight rotary that was in a box lot and it is going on 5 years of moderate use.It does have a Foredom cable and hand piece.I also have Dremels and knockoffs that handle the smaller stuff and higher speed needs.
Tony
Dremel 4.8 volt rotory tool for roughing out? Feisty Power Carving 13 04-15-2010 12:23 PM
Is the dremel Minimite any good? jessio Power Carving 8 10-31-2008 02:09 PM
using 1/4 bits in dremel tool miket Power Carving 15 01-27-2008 11:39 AM
Dremel Tool Deal on Amazon.com meipo Woodcarving Tools, Technology & Sharpening 0 09-15-2006 12:13 AM
Dremel Advantage Tool Ramsey Wood Carving for Beginners 3 08-03-2004 05:14 PM
