Does anyone use this particular model and if so is there a dust removal/vacuum port on it anywhere? I don't see one mentioned in the literature and can't tell from their published images. Thank you in advance. |
Look at your manual and you will see a Dust cup on the left side of your saw about 4" to 6"'s behind your variable speed control. It will be listed as item #12 in the manual. Type in to Google ( Does the Delta 40-160 have a dust port then look at the PDF manual and you will see it. Hope this helps Larry |
#12 on the Parts .pdf I found online shows to be "Mount, Rocker Top"..and not a "Dust Cup"... But thank you. Russ |
| Help with paint removal??? | Midnight Carver | Wood Finishing and Painting | 3 | 01-12-2011 08:41 PM |
| Removal from Classified ads | Shimmy | Message Board FAQ, Suggestions and Feedback | 4 | 11-04-2010 09:26 AM |
| 1200 Delta Scroll | Mr V-tool | Woodcarving Tools, Technology & Sharpening | 3 | 08-11-2010 11:59 AM |
| Dust Removal System | robertf1 | Woodcarving Tools, Technology & Sharpening | 6 | 07-26-2010 03:00 PM |
| Bark Removal | Mr._Munchkin | Carving Wood & Materials | 18 | 08-06-2003 10:50 PM |
