Old 10-23-2009, 10:34 AM
Default Best bandsaw blade size for cutting patterns?
Hello everyone! I was wondering what is your preferred bandsaw blade size for cutting out patterns on blocks?
Thanks in advance.
Old 10-23-2009, 10:47 AM
JIM QUILICI's Avatar
senior WCI reader
Default Re: Best bandsaw blade size for cutting patterns?
depends........
How thick of block you cut....If it is more that 6-7 inches a thin blade will wander from top to bottom....for blocks from around 1-5 inches I like 3/16 skip tooth...or hook tooth....that what I like.....that what works for me.
Jim
to see some of my carvings...click the link below:
http://www.woodcarvingillustrated.co...ry.php?cat=541
If you put the federal government in charge of the Sahara Desert , in five years there'd be a shortage of sand.
Old 10-23-2009, 11:18 AM
I like to have a 1/2 inch blade around for resaw...been using 1/4 4 tpi, but next order will probably go to the 3/16" ...you should gets lots of different opinions on this one!
Old 10-23-2009, 12:47 PM
Carving Addict
A 3/16 Skip tooth, 4 teeth to the inch. Dress the back of the blade. Darn near like a scroll saw.
I just bought a new blade yesterday. I have been a fan of Timberwolf blades for a long time. They didn't have the one I needed at Woodcraft so I bought the Olsen brand. It cuts real nice. I expect it will give good life.
Stay away from the 10 teeth per inch. It does not cut as smooth. That may seem counter-intuitive. But, the softer the wood, the fewer teeth per inch, to clear out all the sawdust.
Old 10-23-2009, 12:54 PM
Mitchell's Avatar
I have an 1/2" Timberwolf on right now.....it's a little too wide to make any sharp turns, but I'm too lazy to change it... Besides, I like to remove more wood with a knife or gouge than with a saw.
To cut out deeper on the blank instead of trying to make sharp turns, I just back it out and make another cut.
My WCI gallery
CCA Website Caricature Carvers of America
Old 10-23-2009, 01:34 PM
What would you guys recommend for really hardwood like Purpleheart. I want to get a blade that will rip as well as crosscut on 3/4" to 1" thick pieces.
http://stickcarving.webs.com/
My Gallery photos.
Old 10-23-2009, 09:02 PM
Claude's Avatar
Ron:
I use the 3/16 4TPI Timberwolf blade when cutting anything from 1/4 inch basswood to 3.5 inch black walnut. The thicker wood just goes a little slower. I've cut olive, purpleheart, padauk, walnut, maple, basswood, oak, pine, plus others, and never had a problem as long as I didn't try to push the wood too fast... and all this has been done on my little 9 inch (under-powered) Craftsman. The Timberwolf blades also track straight, unlike the Sears blades.
My web site
Old 10-24-2009, 01:21 AM
Originally Posted by Claude View Post
Ron:
Claude,
Thank you for the information. I, too, am running a small 9" Craftsman and you're absolutely right on about the Sears blade not tracking. I'll order a new Timberwolf blade.
My Gallery photos.
new bandsaw blade? susieq Woodcarving Tools, Technology & Sharpening 26 10-15-2008 02:46 PM
Cutting Blanks with Bandsaw catbird Wood Carving Tips and Techniques 17 08-12-2008 03:38 PM
bandsaw scroll cutting problem cdcjr Wood Carving Tips and Techniques 18 03-15-2008 12:06 PM
Cutting a Pattern on a Bandsaw jstive Wood Carving for Beginners 10 06-26-2007 01:16 PM
Bandsaw Blade rick-in-seattle Woodcarving Tools, Technology & Sharpening 9 04-15-2005 04:10 PM
