Old 01-04-2012, 05:56 PM
Druid's Avatar
Still not a carver - yet!
Default Arkansas stone - well, 2 and a Carbide
I am fed up of having "cheap and nasty" sharpening equipment so this is coming soon!
I ordered the last 8" set for £30 ($45)
Tri Hone 3 Stone Sharpening Block - Arkansas
If i should have checked first, well, it's to late.
I only add this as i often get the "You should have said 'cos............." Looking forward to the postie though!
I also got this Norton MS-14 for £10 in a local Ironmongers shop, so a good day.
Sorry if my tone sounds a bit off it's 'cos it's a lot of money for me. I read a lot of info here on the site and on the net in general and Arkansas seems a good choice.
Thanks to all of you who's opinions are found with the site search.
Druid
My Carving Photos
I don't believe you have to be better than everybody else.
I believe you have to be better than you ever thought you could be.
Last edited by Druid; 01-04-2012 at 06:32 PM. Reason: the other thing i bought - added!
Old 01-04-2012, 06:22 PM
bluegrass
Default Re: Arkansas stone - well, 2 and a Carbide
I have tried power sharpening and ruined a few tools. I always go back to the old basics. I do use a buffer though.
Steve Brown Woodcarving
Old 01-04-2012, 07:10 PM
davidinsarasota's Avatar
Beautiful Druid. They say to use plenty of oil so it does not 'glaze'. Also supposed to have something to flatten them.
Old 01-04-2012, 09:41 PM
Druid's Avatar
I already made a strop (12" hardwood with leather 2 sides) so that's covered, works well, Oh the back of a notepad and a marble tile 6" Sq. is also in the kit. All i need to do now is repair the damage caused by learning on bad stones.
Duly noted, thanks!
My Carving Photos
Old 01-04-2012, 10:02 PM
Druid: yes, lots of money but the results will be gratifying.
Get a new & cheap oil stone. LOTS of motor oil, I use 5W40. Grind the old stone against the new one in a random pattern, flush with lots of oil and paper towel for the drool. Also, I use a cheap, brass-bristly BBQ brush for scrubbing oil stones to get rid of the swarf.
Water stones (which I recommend) can be flatted against a big mill file that's clamped to the bench. If you don't beat the bejeezlies out of your tools, waterstones and fine Arkansas stones will last a long time. Soft? Yes. Just don't lean into it, you're not trying to sharpen a plowshare.
Put some black felt marker on the bevel so you can see where the metal is coming off.
LOCK your elbows to your side so you sway back and forth = that way, you can't raise your elbows to round off an otherwise flat bevel.
Make some silly triangles with a protractor so you can reassure yourself what 10 degrees or 15 degrees really is.
Old 01-05-2012, 01:18 AM
Hi Druid
I bought a hard Arkansas 2x8" stone 30 years ago and still use it. I use mineral oil for a lube. It is a good idea to have different grades of stones. Course,medium,and hard. Then just practice and pay attention to what you are doing
Bruce
www.brucebirdantlercarving.com
Old 01-14-2012, 05:26 AM
Druid's Avatar
Well it's "lost in the post" and no new stock until the end of February so now i have to wait or go with a 6" as a replacement. Trouble is with my luck if i go with the 6" the 8" will turn up as soon as i start to use the 6" and then i will have to return the 8". Gutted is an understatement.
My Carving Photos
Old 01-14-2012, 11:34 PM
Well. Isn't that enough to rot your socks? Here I thought that Canada & Storage were the only ones to do that.
In the mean time, see if you can find some automotive, paint-finishing, sandpaper.
Usually 1500 and 2000 grits, wet&dry. Firmy attached to good flat surfaces,
it isn't half bad. I prefer stones but the papers are the foundation for the "scary-sharp" edge work and results.
Old 01-25-2012, 08:35 AM
Druid's Avatar
Well the saga continues-
I opted for a 6" as a replacement and it arrived today, BUT well you can see in the photo below. Yes they will replace it and do a visual inspection before dispatch but i still feel very let down by this service.
My Carving Photos
Old 01-25-2012, 09:09 AM
Gulf Coast Handyman's Avatar
May have happened in the mail??
Dave
Conical Slip Stone aka Gouge Stone Wayne Vipond General Wood Carving 6 12-27-2010 09:33 PM
Carbide bur from Sears John_C Power Carving 4 09-13-2009 02:25 AM
Arkansas Stone ocd Woodcarving Tools, Technology & Sharpening 0 01-24-2009 05:40 PM
Cleaning Arkansas oil stone James A Woodcarving Tools, Technology & Sharpening 2 07-23-2008 08:56 AM
Renewing an Arkansas stone? BlackDog General Wood Carving 11 10-07-2003 11:10 PM
