Old 07-19-2006, 09:16 AM
buckbeans
Default abrasive grade for burke system
I was looking into the burke sharpening system amd was wondering what grits most are using for the two abrasive wheels before going to leather or buffer?
Old 07-19-2006, 09:47 AM
Default Re: abrasive grade for burke system
I have been using 120 and 240 grit.
Old 07-19-2006, 11:52 AM
buckbeans
What kind of grit do you use on the leather strop and buffing wheels?
Old 07-19-2006, 06:43 PM
I use white rouge.
You can use whatever you have as long as it will stay on the wheels.
Old 07-19-2006, 10:04 PM
buckbeans
isn't there a big transition gap going from the 240 grit wheel to the buffer?
Old 07-19-2006, 10:29 PM
I suppose there would be if you didn't use your sharpener very often.
When I am sharpening, I usually change abrasives 2-3 times a day.
The 240 grit goes to about 320-400 grit in just a few minutes; by the time I need to replace the abrasive it is probably 600-1000 grit.
If I were to start with something like 400 grit, I would need to change abrasives every half hour.
Also I don't go from 240 to buffer, I have a sisal wheel with compound that I use
between them. This takes out most of the scratches before buffing to a mirror finish.
Old 07-20-2006, 06:56 PM
buckbeans
thanks for the reply.
I was wondering about that gap. Are you using emery paste on that sisal wheel?
Old 07-23-2006, 10:47 PM
Go to "Buffing Wheels" and look for the sisal wheel.
http://www.texasknife.com/store/s-pa...frameStore.htm
Texas Knifemakers also supply me with the sewn muslin buffing wheels for polishing.
Go to "Buffing compounds" look for the 925 Dark Grey compound I use on my sisal wheel.
I use the Pink No-Scratch on my polishing wheel.
Old 07-24-2006, 10:07 AM
buckbeans
thank you very much
I will try that sisal wheel
Old 07-28-2007, 04:28 PM
Originally Posted by rick-in-seattle
When I am sharpening, I usually change abrasives 2-3 times a day....
Kind of an old thread, but I did a search, and my question seemed best answered here.
I'm curious how your setup is on how you change out your abrasives? I bought a used Burke system, and the paper that's on it is glued on... doesn't seem that easy to change out.
Thanks
cbw
John Burke Sharpening System Donna_T General Wood Carving 10 10-04-2009 05:56 PM
HELP....does anyone have a system.... Callynne General Wood Carving 18 06-07-2006 08:27 AM
Identification of an abrasive wheel Thomp Woodcarving Tools, Technology & Sharpening 4 03-11-2006 10:17 AM
Which pyrography system to buy? Dan C Pyrography and Woodburning 7 11-07-2005 01:42 PM
Replacement Parts for Burke Type Sharpener Greyhair Woodcarving Tools, Technology & Sharpening 2 11-01-2005 11:29 AM
