Old 05-31-2009, 08:48 PM
Gulf Coast Handyman's Avatar
Default 1 x 30 Belt Sander With Leather Belt
I was given some good advice and thought I would pass it on. The leather belt on my upside down belt sander (which is only 4 months old) got so stretched out that even with the tension turned all the way, the belt still flaps when running. A friend of mine suggested lightly spraying the belt with water will shrink it, then when the machine is not in use loosen the tension. I did this a week or so ago and it seems to help. BTW when the belt is tight it works great !
Dave
Old 05-31-2009, 09:50 PM
Claude's Avatar
Default Re: 1 x 30 Belt Sander With Leather Belt
Sounds very much like the recommended procedure for bandsaws: remove tension when not in use. Thanks, Dave - I probably wouldn't have thought to remove tension on a belt sander with a leather belt, but now that you mention it, it makes sense!
My web site
Old 06-08-2009, 09:24 AM
stickman's Avatar
Thanks for the tip!
Michael
Old 06-08-2009, 01:02 PM
Your welcome Michael. Claude, it does make sense, that is if I can remember to loosen the tension
Dave
Old 06-08-2009, 02:41 PM
Mudbone's Avatar
Member in training
I just got a 30" belt sander and will be keeping the sander belt on it. Is it also recomended to releive tension on those or just the leather?
Old 06-08-2009, 07:47 PM
Sorry Tom I am not sure, maybe one of the others might know. I also have an older Delta 1x30, I use this one only for sanding, I never loosen the tension and never had a problem ??
Dave
Help needed on a 1" belt sander Ron T Woodcarving Tools, Technology & Sharpening 13 05-22-2009 12:26 AM
delta 1'' belt sander stickman Woodcarving Tools, Technology & Sharpening 38 12-27-2008 06:04 PM
UPS vs strip belt sander Dennis Taylor Woodcarving Tools, Technology & Sharpening 3 08-29-2008 08:48 AM
Can a 4" belt sander be used as a sharpener? chuckt Woodcarving Tools, Technology & Sharpening 7 02-14-2007 06:50 PM
Belt Sander Bargain Jon Harl Woodcarving Tools, Technology & Sharpening 10 01-02-2006 11:29 AM
