Old 10-20-2002, 09:35 AM
Guest
Guest
Posts: n/a
Default Re: softening hard wood to carve relief
The bevel on pfeil tools does seem to be made for soft woods. I have both pfeil tools and Robert Sorby tools and the Sorby tools have a much thicker bevel, about 22 degrees as opposed to about 15 degrees for the pfeil. I strongly caution against re-bevelling unless you have a grinder like a Tormek that can hold a consistent angle. Besides, it will eventually eat up your expensive tools. Consider buying a few English tools that are bevelled for hardwoods.
Old 10-20-2002, 10:22 AM
Just a thought, but it might not be the hardness of the wood that was the problem. Were you running straight cuts, or applying a prying force to the edge. If you were down in a deep cut, and tried to pry the piece out, that may have caused the break. I've broken one small v tool and that is exactly what I had done. Also when teching Scouts to carve relief, we have had several tools break because of prying.
It's an easy thing to do, and it has to be thought about constantly when doing deep cuts.
Old 10-20-2002, 07:26 PM
FatEddy
Guest
Posts: n/a
I ordered a number of Stubai midsized tools and was a little miffed when they arrived with different sized handles. But, after studying them a bit I discovered that the size of the handle and thickness of the steel varied with the intended (theirs) use of the tool. i.e. those meant for making deep/large cuts had larger handles and thincker steel while those meant for lighter work had smaller handles and thinner steel. Seems to work o.k. because I just finished an oak acanthus leaf with no problem . Might this be the case with the Pfiel tools? Curious, because I'm thinking of getting some to add to my collection.
Old 11-04-2002, 03:34 PM
thor
Guest
Posts: n/a
Hi, just wanted to stop back by and say that the project is done and turned out better than I thought it would as frustrated as I was with it.
It is a 3' X 36' poplar board with a Nordic design on it that is now incorporated into a bench.
The water/alcohol mix wasn't working as I think I was afraid to get it very wet. I didn't want it warped at all since it had to fit into the piece of furniture. I tried putting lemon oil on it (soaked) and it did soften it. I carved away all of the oil stain, and now with the tung oil finish it looks very rich.
Thanks for all of the suggestions.
Oh, sorry to hear about the broken Pfeil tool. That's what I use, and I would be heart broken if one of mine broke!
Thor
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f51/softening-hard-wood-carve-relief-4320/
Relief and Chip Carving [Archive] - Page 4 - Woodcarving Illustrated Message Board This thread Refback 01-15-2008 04:01 PM
Relief and Chip Carving [Archive] - Woodcarving Illustrated Message Board This thread Refback 09-11-2007 12:49 AM
When you run out of wood to carve... Marci MN Off Topic 3 12-09-2006 02:57 PM
Adding wood to a relief carving nadcarves Relief and Chip Carving 13 11-29-2006 10:36 AM
Relief wood ready to carve on? Kim Carving Wood & Materials 13 02-28-2006 02:22 PM
Hard Maple Mryooper General Wood Carving 10 01-28-2006 01:42 PM
do i carve wet or dry wood joe(rookie) General Wood Carving 7 04-05-2005 07:46 PM
Santa Carving Contest
