Old 01-21-2011, 01:33 AM
Default Power Sanding Relief
Hello, I'm getting into relief carving and was wondering what are some nice ways to power sand the wood? There are a lot of little areas that are hard to get into so I was thinking maybe abrasive pads on a rotary tool. I like my carvings to be a little rough so I don't mind if the sanding eats into the wood, but just need an easy and fast way to get up into those tight spaces.
-Kenny
Old 01-21-2011, 08:38 AM
Donsexton's Avatar
Default Re: Power Sanding Relief
I have some small flap wheels that have a 1/4" shaft and some tiny flap wheels that have a 1/8" shaft. I got mine at the welding supply house I also have some small foam sanding pads no bigger than a penny that may help you. Go to your local pro welding supply house I bet you will find some things that you can make use of.
Sanding bbeery General Wood Carving 14 02-28-2012 06:49 PM
Power relief carving? sparrow85 Wood Carving for Beginners 7 12-12-2006 06:39 PM
power relief carving a door fishcarver2004 Wood Carving Tutorials 31 07-18-2006 05:31 PM
Relief carving with power?? Alice in Wonderland Relief and Chip Carving 8 06-30-2006 04:05 AM
Sanding - how much is enough? mik1947 Wood Finishing and Painting 10 01-22-2006 08:02 PM
