Relief and Chip Carving | |||
Sure it turned out good the guy has been doing it for yrs. LOL The wider the letter, regardless of UC/LC, the more you have to lean the knife. You can't maintain a "chip carving angle" or else you will go too deep. Take a look at store or village signs. They are really pretty shallow to take advantage of the guilding. Instead of a mill knife you can use a wide #2 and a straight chisel. The book show the author using redwood which is hard to get and $$. Most sign makers in this area use a synthetic that carves like wood. Bill K.
__________________ Every day should be unwrapped like a precious gift. |
#13
only know that he no longer uses redwood but some material that is used in the trade. A search on sign material might help you. Bill k below is one result of search Precision Board™ HDU is a rigid, closed cell, high density urethane material. It can be sandblasted, routed, carved, sanded, or machined. It will not crack, twist or curl after long exterior exposure, making it the ideal replacement for wood signs.
__________________ Every day should be unwrapped like a precious gift. Last edited by papasar; 07-15-2010 at 05:17 PM. Reason: addition |
#14
Highland sells a mill knife kit for about $45, but all you need for lettering is the sharp point blade, and the handle. I called them, and they will sell the handle for about $18, and the sharp point blade for about $6.
| Dawt Mill | chuckbolton | Relief and Chip Carving | 6 | 03-14-2009 01:00 PM |
| New Mill Finished | Ron Davidson | Relief and Chip Carving | 12 | 09-28-2007 07:37 PM |
| Mill Knife | ljhj | Woodcarving Tools, Technology & Sharpening | 4 | 03-22-2007 08:38 AM |
| Mill Update | Ron Davidson | New Projects and Works in Progress (WIP) | 4 | 03-16-2007 07:45 PM |
| mill ends | jordan | Carving Wood & Materials | 7 | 09-17-2003 11:16 AM |
