Old 03-31-2009, 10:46 PM
ERICSFISHIN's Avatar
Default finished with this project?
I downloaded these pictures and started to try relief carving. I dont know what else to do or does it look finished? I am out of ideas.
Old 04-01-2009, 06:42 AM
Joy's Avatar
Joy Joy is offline
Default Re: finished with this project?
The insect looks great. I think the other needs more definition between the layers which could be accomplished with some undercutting.
Old 04-01-2009, 08:00 AM
tnartist05's Avatar
Tn.Carver/Artist
When you are through with the center,go back and carve down all three{top and the two sides}leaving the back ground boardless and flat with out thoses uneven looking framed edges. Then stain or paint it. Hope this might have helped you some.
Heres a relief carving of some bears carved in a old found board even had holes in it.I run a carving off the edges at times. Hope this might help you some.
I'll keep ck'n on this carving,you did a good job carving the center of it.
Forrest
Your Attitude will always determine your Altitude.....(Aim High!)
"Im not the best, dont try to be,the fun part is always just trying your best"
Home Page:
http://www.facebook.com/home.php?ref...18&ref=profile
http://tnartist05.blogspot.com/
WCI Carvings Gallery
http://www.woodcarvingillustrated.co.../1/ppuser/4908
Old 04-03-2009, 09:54 AM
Joy Is right. Undercutting will bring out this carving with some "snap" and give the illusion of depth. I'm not very fond of painting, but some carvers can really pull it off. I've seen a lot of carvings with just an oiled finish that were fantastic and by the same token I've seen painted ones that were great! Follow your own ideas is the best advise.
Indian123
Bobla76
Finally finished Halloween Project Merle Rice Holiday 24 02-09-2009 09:14 AM
sanding a finished project csquish General Wood Carving 3 10-23-2008 09:59 AM
Latest Project finished. hugh Animal and Bird Carving 36 02-22-2008 04:17 PM
New project finished masker001 New Projects and Works in Progress (WIP) 3 09-24-2006 08:00 PM
Finished First Carving Project bronco Wood Carving for Beginners 12 12-29-2005 05:00 PM
