Old 10-04-2006, 12:40 PM
Slow Learner
Default Re: 1st relief carving-need help
I have been crocheting like crazy for the 1st of my fall craft fairs this Saturday, but I have finally done some more work on my dolphins. The rounding and undercutting seem to be going well. I had to resort to sanding to fix all of the little cut lines in the undercut areas. I have also started sanding the top--I like the smooth look better. My last major problem is still the crack in the far right dolphin. I have decided to go with putty instead of glue to fix it, but have not gotten up the courage to do anything on it yet.
Thank you again to everybody for suggestions and advice.
micky
PS--The last two pictures are of Pikes Peak and the changing aspens--couldn't resist adding them as it was a beautiful weekend here.
1st-relief-carving-need-help-tn_dolphin-update1.jpg  1st-relief-carving-need-help-tn_dolphin-update2.jpg  1st-relief-carving-need-help-tn_dolphin-update3.jpg  1st-relief-carving-need-help-tn_pp-best.jpg  1st-relief-carving-need-help-tn_aspens.jpg
Old 10-04-2006, 01:03 PM
in the picture, and sometimes pictures are misleading....it looks like you can narrow that dolphin down by cutting away the wood on the right side of the crack, looks like there is plenty of body for the dolphin and enough for the fin? just an idea.
Old 10-04-2006, 06:29 PM
Slow Learner
Thanks Hi-Ho. I thought about that as well in my original post here, but I have been worried about the perspective if he is much smaller than the others. Probably does not matter, and it might be an easier fix.
Old 10-04-2006, 07:48 PM
well hard to go by pictures, but it looks bigger than the others anyway, may just balance out just right! lol
Old 10-05-2006, 05:43 PM
Slow Learner
Keep forgeting to give credit to the author of the pattern. It was in a Weekend Projects book by John Hillyer. Obviously I did some modifications as it was intended to me a plaque and the dolphins were swmimmng sideways.
Old 10-06-2006, 11:00 PM
Too late to be of help.. But,many times when this is happening, you can seal the outside surface, with a wax, and drill out the center...The cracking occured because the outside was drying and shrinking...By sealing the outside and allowing the center to ,now, dry and shrink, it will pull the outside surface in and close up the crack...Does not work every time, but has an excellent track record.. This is a tip from a real maniac, a green Walnut carver, and they are the worst kind..I know a couple....Cordially NAD
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f51/1st-relief-carving-need-help-9661/
Relief and Chip Carving [Archive] - Page 3 - Woodcarving Illustrated Message Board This thread Refback 01-21-2008 07:20 PM
Relief and Chip Carving [Archive] - Page 2 - Woodcarving Illustrated Message Board This thread Refback 10-30-2007 01:13 PM
First Relief Carving! Thanks everyone! Learning2CarveDaily Wood Carving for Beginners 5 02-11-2007 06:15 PM
Relief Carving cdlange Relief and Chip Carving 1 03-02-2004 09:45 AM
My 1st relief carving cffrenchy Relief and Chip Carving 11 05-18-2003 08:25 AM
Relief Carving Guest Relief and Chip Carving 0 03-29-2003 01:55 AM
relief carving masker001 Relief and Chip Carving 2 11-12-2002 07:01 PM
