Go Back   Woodcarving Illustrated Message Board > FAQ > Message Board FAQ, Suggestions and Feedback
Old 09-26-2008, 02:56 PM
Terry Vance's Avatar
"Old" Guy
Default Question about the Forum
Why is it that when I open a subject area ie Welcome New Members that each thread will be a different width. Some will show up in the space alloted and I can read them and others I will have to scroll left & right to read.
Just curious. Seems that they should all be the same width.
Keep carvin'
God bless you,
John 3:17
http://www.picturetrail.com/terryvance
my WCI gallery
Old 09-26-2008, 03:06 PM
BobD's Avatar
Technical Editor
Default Re: Question about the Forum
The text should wrap in most cases. I see the situation you describe a lot when someone cuts and pasts a photo into the text, or uses the < img > command.
Old 09-26-2008, 07:14 PM
xsailer's Avatar
Try holding the "Alt" key down and at the same time touch the " - " once for each downsize you want. Hope this is an answer to your question.
Old 09-27-2008, 07:44 PM
"Old" Guy
I should not have to change the display size everytime I look at a different thread on the forum. The opening to this thread that I typed in yesterday fit just when I submitted it and today it is way to wide for my screen. There are no images or photo's attached. Just seems strange to me.
Keep carvin'
God bless you,
John 3:17
my WCI gallery
Old 09-28-2008, 01:51 AM
CREID's Avatar
I have the same problem, kind of irritating!
curt
Old 09-28-2008, 11:09 AM
xsailer's Avatar
You're right "it is irritating". My problem really went away after buying a new wide screen monitor. I played with changing the resolution formula within one of the Control Panel choices with some luck before I changed to a new computer. It is extremly irritating I know. Thomp was the one that gave me the contrl/- suggestion and it worked but still not satisfied having to do it when I new if I could just find 10 yr old to fix the problem it would go away. No slam meant just a fact.
Old 09-29-2008, 09:37 AM
BobD's Avatar
Technical Editor
Can you provide a link for me to troubleshoot the problem with?
Old 09-29-2008, 04:52 PM
"Old" Guy
This thread is extra wide on my machine as is the following.
bandsaw set up?
I have the size on my screen set at 100%. There are a lot of threads that actually fit with room to spare and then those that are really wide.
Thanks for checking,
Keep carvin'
God bless you,
John 3:17
my WCI gallery
Old 09-29-2008, 05:41 PM
admin's Avatar
Administrator
tvance, or anyone having that problem, can you let me know what resolution your monitor is using so I can try to replicate the issue from my end? On windows you can see this by right clicking on a blank part of your desktop and selecting "properties" and then the "settings" tab, it is listed in the slider kind of in the middle. On macs its in the apple menu, system preferences and monitors.
thanks...this sort of feedback makes this forum a better place for everyone.
Old 09-29-2008, 07:28 PM
"Old" Guy
Mine is 1024x768 on a 17" CRT monitor.
Keep carvin'
God bless you,
John 3:17
my WCI gallery
Question About Forum Terry Vance Off Topic 6 03-19-2008 11:53 PM
new to this forum ammuabbu Welcome Members 5 06-30-2007 01:58 AM
New to For Forum Robert Crisp Welcome Members 9 05-31-2007 04:35 PM
New to the forum! USMC35 Welcome Members 7 04-08-2007 08:26 AM
A New Forum Teri_Embrey General Wood Carving 10 01-20-2004 03:17 AM
