Go Back   Woodcarving Illustrated Message Board > FAQ > Message Board FAQ, Suggestions and Feedback
Old 04-01-2008, 12:14 PM
Just Carving's Avatar
Teddy bear carver
Default Gremlins at work?
Since the message board was redone, periodically, I've been having trouble when I hit the "New P-osts" button.
I get the standard Internet Explorer "Page cannot be displayed" page with :
res://shdoclc.dll/DNSERROR.HTM#http://www.woodcarvingillustrated.co....php?do=getnew
in the Internet Explorer address box.
Usually I hit the "back" button and try again. Any idea what's going on--it is a nuisance.
Bob L
Old 04-01-2008, 12:18 PM
BobD's Avatar
Technical Editor
Default Re: Gremlins at work?
I've asked Claudio to look into it.
Old 04-01-2008, 12:19 PM
Teddy bear carver
Thanks BobD.
Old 04-01-2008, 12:57 PM
admin's Avatar
Administrator
I think I know what the issue might be. It is a bit technical though...I made some changes which *should* make this go away, or at least happen a lot less often. It should take about an hour or so for them to filter across the Internet. If you continue to get these same errors any chance I can get some info specific to your connection? Email me off the board if you would at webmaster@foxchapelpublishing.com and I will run through what I need and how to get it.
--Claudio
Old 04-01-2008, 01:50 PM
Teddy bear carver
Shouldn't be a problem as far as the info. if I still have the problem. I'm not certain, but it seems to happen at work. We have a LAN (which also has gremlins from time to time), and that could be causing the problem. I didn't even give that a thought until you mentioned my connection. So, I'll see what happens. Thanks Claudio.
Greetings and 1st work Sailing-Randy Welcome Members 10 01-05-2008 12:37 AM
New old work? mark yundt New Projects and Works in Progress (WIP) 15 11-07-2007 12:11 PM
little more work needs to be done Kenny_S New Projects and Works in Progress (WIP) 27 05-09-2007 06:53 PM
First work Francesco Wood Carving for Beginners 10 11-27-2006 02:24 PM
A bad day at work! decoycarve General Wood Carving 10 06-10-2005 08:08 AM
Santa Carving Contest
