Go Back   Woodcarving Illustrated Message Board > FAQ > Message Board FAQ, Suggestions and Feedback
Old 10-14-2010, 08:03 PM
John T's Avatar
John's Just Carving Bears
Default Chainsaw not cutting straight
My chainsaw is not cutting straight. It cuts off on an angel so I don't get straight end cuts. I sharpen my chain often by hand ( however I do forget at times ) would this be one of the problems not sharp all the time. Also should the bar be dressed all the time and flipped over. It is a fairly new chain but the bar is older. I take the chain in to get sharpened by machine the odd time. Should I do this more often.
Any advise would be greatly appriciated.
Thanks
John
Old 10-14-2010, 08:49 PM
Donsexton's Avatar
Default Re: Chainsaw not cutting straight
I will give you my “Two cents my ten cents for free” If you have a new chain and your bar is straight then YOU ARE FAVORING one side or the other. I think you know already that uneven sharpening will make the bar follow the sharp side. Lets say your bar is perfect your chain is perfect and it still pulls then its you. This is just me Ole Don here I know I cant cut straight without a line to follow my saw will hook my golf swing will slice. Make yourself a line to follow I bet it will help you.
Old 10-15-2010, 03:17 AM
DBarker's Avatar
Woodchuck
Here is what i have found over the years. If you hand sharpen you might be getting one side shorter than the other. or if you do a lot of shape carving, your bar may be getting worn or widend in the runner for your chain, in which case you can get it narrowed with a bar pull or roller.
Old 10-15-2010, 09:21 AM
TreeWizard's Avatar
When the chain gets loose it tends to cut to one side. Also, I believe in dressing the bar every time I take the chain off and have it sharpened using a machine. In my case that's after I cut about 10 face cords of firewood, I dress the chain as needed with a file several times during those 10 face cords.
Paul.
Old 10-15-2010, 03:58 PM
Donsexton's Avatar
I like to say my slanted cuts are my artistic interpreation.
Old 10-15-2010, 08:00 PM
John T's Avatar
Thumbs up Re: Chainsaw not cutting straight
Thank You for the input everyone.I think I will get the chain sharpened by a machine,dress my bar and take up the slack in the chain a bit when I put it back on and see how that works and then I will know if its me or not Thanks again
John
Is possible to burn perfectly straight lines with a metal straight edge? eulnuj Pyrography and Woodburning 3 05-20-2010 05:59 AM
Bent vs Straight mtngoat Woodcarving Tools, Technology & Sharpening 9 03-24-2009 01:41 PM
Straight Tequila Night!!! Scott Hagerty General Wood Carving 6 08-19-2007 04:42 PM
knives from straight razors? RUssL. Woodcarving Tools, Technology & Sharpening 7 12-29-2006 07:21 PM
Straight Lines whittlinwit Caricature Carving 3 05-24-2003 06:52 AM
