Old 05-29-2003, 10:39 PM
Guest
Guest
Posts: n/a
Default wood burning
I currently am working on carving a bird, the stumbling point that I have come upon is detail for the feathers. Would burning the feather detail in work. Any other options would be greatly appreciated.
Thanks,
Matt
Old 05-29-2003, 10:47 PM
whittlinwit
Guest
Posts: n/a
Default Re: wood burning
Yes.
Old 05-30-2003, 06:03 AM
Donna_T's Avatar
Matt,
Burning feather details will give you the finest details you can achieve--especially with practice. You can use a micro v-tool, but there is just more you can do with a burner tip than just make fine lines. For instance, when you put the center barb on a feather, you can go back over the line and lean the tip toward the outside of the feather to compress the wood slightly away from the barb to make it stand out. As you outline each feather, you can do this also rather than carving around each feather to soften the look and make it the 'tinyest' bit of a different height.
So, burning would be the best option for the best look.
Donna T
Old 05-30-2003, 07:37 AM
icarve2003's Avatar
Matt,
Definately burn the detail on feathers. That is all I use when doing the primaries, secondaries, tertials, etc.. When doing the softer looking feathers on the chest 'belly, and mantle, I use the dremel tool with a small stone. It gives them a softer fluffier look.
Birds are what I carve the most. I started out doing ducks but I enjoy doing songbirds more. I found that the ducks were all too similar.
Let me know if you have any more questions.
Chris
Safety first
Old 05-30-2003, 10:26 PM
Donna_T's Avatar
I Carve:
Which stone do you use for those 'soft' feathers--color, size, and shape? I've wanted to try that process, but have never heard which stone to use.
Thanks for sharing details.
Donna T
Old 05-31-2003, 05:55 AM
Guest
Guest
Posts: n/a
For soft edges after burning use the white ball shape cutters to soften. I space allows a long white cutter is used. A blue cerem cut from Foredom may work but white is recomended.
Old 06-03-2003, 07:21 AM
icarve2003's Avatar
Hi Donna,
I use a small white inverted cone ???(don't know how else to describe it.) I try to get one as small as I can and I use the edge of it to sort of 'draw' in the feathers. I find if you rough in groups of feathers before you start actually texturing, it makes them look a lot fluffier.
I've seen a demo on the web somewhere. I'll try to find it and I'll post the link.
Chris
Safety first
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f40/wood-burning-2274/
Animal and Bird Carving [Archive] - Page 7 - Woodcarving Illustrated Message Board This thread Refback 12-18-2007 03:52 PM
Animal and Bird Carving [Archive] - Woodcarving Illustrated Message Board This thread Refback 09-03-2007 11:25 PM
Wood Burning Book! Irish Publisher Feedback 7 06-12-2007 10:17 AM
Wood Burning fun Nightsky_angel Pyrography and Woodburning 8 11-21-2006 05:34 PM
Preparing wood for burning saclark Pyrography and Woodburning 4 04-10-2006 01:34 PM
Wood Burning College Project Irish General Wood Carving 13 04-23-2005 12:38 PM
Wood Burning Carver_Boy General Wood Carving 15 12-18-2002 09:34 PM
Santa Carving Contest
