Old 12-23-2007, 03:51 PM
Default shark teeth
Hey Need some advice on getting teeth in a 3ft shark carving { a 2in thick plaque that will hang the wall} I'm plagerizing a Wick Ahrens white shark as best I can. Im using juniper {not strong enuf for teeth} Ive cut the lower jaw off and was going to use tooth picks as inserts. Am I on the right track? It looks good so far but good teeth are a must.
Old 12-23-2007, 06:15 PM
Default Re: shark teeth
Hi...have you thought about using real ones ?
Old 12-23-2007, 07:19 PM
that might be excellent
Old 12-23-2007, 08:34 PM
Eddy Smiles's Avatar
木彫る
The shark might have other ideas! Ha! Ha! Have you thought about getting a piece of 1/4" thick basswood at a craft or hobby store and carving individual teeth from it? Another trick is to use craft plywood. It's only 3-ply and not as thick as the basswood. To save time you can scroll saw the basic shape from either medium and then finish up with knife and sandpaper. Apply a bit of Titebond to the base and glue them in place. You could even pre-finish them.
Old 12-24-2007, 08:49 AM
You could use Tagua nut for teeth as well.
Old 12-24-2007, 08:58 AM
squbrigg's Avatar
Tagua nuts is a good idea Hi Ho,...... I've used Holly for teeth before with good results.
link to Gallery photos
Old 12-24-2007, 10:01 AM
Dylan's Avatar
If you want white teeth you might try using PVC pipe. I've seen people use it for small parts, such as horns and teeth. After a while I think it turns ivory in color and from what I've heard it carves fairly easily.
Dylan
Check out my website at www.OldOakEnterprises.com
Old 12-24-2007, 10:12 AM
bird carver's Avatar
One thing that looks just like shark teeth is rose thorns. The only problem is finding them along with trying to find a dead plant, unless if you take them from a live one sparingly. Bird carver
Old 12-24-2007, 04:22 PM
Hey As luck would have it I find myself fresh out of tagua nuts but all stocked up on PVC I cut a bunch of small pegs out of a piece of 3/4 PVC trim and it worked the best easy to carve and they look like nasty ol shark teeth with no effort You guys are the best thankyou
I have to admit that I wouldn't know a tagua nut if it rolled out of my shorts
Merry Christmas
Willie
Old 01-12-2008, 08:14 AM
squbrigg's Avatar
Do we get to see the results? I'd enjoy it.
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f40/shark-teeth-15371/
Animal and Bird Carving [Archive] - Woodcarving Illustrated Message Board This thread Refback 02-25-2008 08:19 PM
Woodcarving Illustrated Message Board This thread Refback 12-23-2007 05:52 PM
Carving watermelon "Billy Bob" teeth Lightningbolt General Wood Carving 5 08-12-2007 07:39 AM
Carving teeth Blake Lunsford Caricature Carving 7 10-11-2005 01:07 PM
