Old 07-11-2003, 04:13 PM
howard077
Guest
Posts: n/a
Default Rotary or drummal??
Any tips out there for those of us who on;y use rotary and drummals.
I love mine but just started my brother in law doe flotable duck decoy's.
Old 07-12-2003, 08:52 AM
Guest
Guest
Posts: n/a
Default Re: Rotary or drummal??
Hi Howard 007. I teach power carving with Dremel or Fordom machines with a flex-shaft. I've been carving for about eight years with power. One of the most important things is getting rid of the dust so you don't breath it. Next in line is working with each bit at all speeds so you know what each one will do, and at what speed and presure they will burn the wood you're working on. If you don't have the bit running true it will cut un-even and you cant make fine line cuts. To make sure its runing true turn the machine on at its lowest speed, take a small open wrench and place the open end on the shaft below the cutter, if you can feel it bumping then its not running true. Losen the chuck and give the bit a quarter turn and check it again untill you feel it running smooth. The one wood you don't want to use is pine! The sap in the grain lines will gum up all of your bits and sanding drums.
If you have any questions email me and I'll try and help you.
Jack D.
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f40/rotary-drummal-2263/
Rotary Tool and Kit. - Woodcarving Illustrated Message Board This thread Refback 08-22-2007 05:10 AM
rotary cutters Alice in Wonderland Woodcarving Tools, Technology & Sharpening 0 01-20-2006 06:39 PM
Rotary Tool and Kit. dart Off Topic 1 12-28-2005 11:46 AM
power rotary carvers finlander General Wood Carving 15 12-06-2005 08:15 PM
sharpening rotary burrs macktruck General Wood Carving 3 03-13-2004 06:40 PM
rotary de-fuzzer#23 marsh Guest Animal and Bird Carving 11 07-03-2003 10:24 PM
