Old 01-18-2010, 09:33 PM
Default project
I have someone who wants me to carve an akita head on a peice of wood that is 15" x 15" and that can be glue to their front door when done. Any thoughts?
thanks
Tammy
Old 01-19-2010, 08:57 AM
Joggernot's Avatar
Default Re: project
No help on carving, but I use screws from the other side of the door to hold my carvings. That way when I leave, the carvings can go with me, and I just have to fill the holes. Also, it is a more "positive" hold for the carvings.
Joggernot
Beginner
Rockport, TX
Old 01-19-2010, 11:37 AM
squbrigg's Avatar
Default Re: project
Sounds like an interesting project. What material are you thinking of using? I look forward to seeing your progress on this one.
link to Gallery photos
Old 01-19-2010, 11:41 AM
Blackjaxe's Avatar
Blackjaxe
Default Re: project
There's a much better way to attach the carving. You will need a router bit called a "KEYHOLE" It works by using a plunge router, the bit has a head the size of a #10 screw and then the shank comes in to the size of the actual diameter of the screw ( not the head)
Most wall clocks have that method of attaching the clock to the wall. This way if you need to remove the carving its is easly done and as for the screws simply remove and use a filler.
Ken
" I can't remember the last time I forgot something"
Old 01-20-2010, 01:42 PM
Default Re: project
Well i am not sure what wood to use I am waiting to hear if she wants an actual head of an akita or like what my pins are 3 d on flat surface. What are your thoughts?
thanks
Tammy
New project Pol Pyrography and Woodburning 3 01-18-2010 09:49 PM
Another Project Nick77 Wood Carving for Beginners 8 06-14-2009 03:07 PM
Another Project Nick77 Wood Carving for Beginners 6 06-02-2009 07:18 PM
New Project Done!! Ron Davidson Caricature Carving 18 07-17-2006 03:40 PM
New Project!! Ron Davidson New Projects and Works in Progress (WIP) 15 12-29-2005 09:36 PM
