Animal and Bird Carving | |||
I'm sorry that I didn't make my original request clear. Let's submit all ideas (materials, techniques, sources for techniques, etc). Those that are going to enter contests will know if they can use it or not. If you are are interested in entering competitions please ask questions if certain things can be used. Most competitions have little different rules. So in the mean time let the creative juices flow...give ideas and we'll sort it out later. Idea: Try FLORAL WIRE... that can be purchased from most hobby stores including Walmart...for stems of leaves and vines. Thanks for all the submissions and let's keep 'em coming! |
#12
Someone mentioned before an on line catalog but here goes, Micro-Mark: The Small Tool Specialists, it's one of the best in Gismos,Thing of Ma Jigs, I have ever seen. It has every thing for micro tools known and very good supplies of ' habitat makers',rocks grass trees,wire twisters for small branches,it's great. I think a new thread regarding habitat sources and no how would be great. Prices are great and you can spend any between $2.00 to a few hundred bucks and "no Ken" I will not buy any more spendy tools without checking a less expensive route". Oscar |
#13
I've reread the request again and thought that the words "Creating " meant exactly that....in other words.."Not Found Objects". I was going to do a blow by blow photo process of doing a branch with peeling and split bark. I've now have second thoughts about doing this as I'm a bit confused as to where the creating part got thrown to the wolves. Doesn't really matter...I'll sit this one out. ![]() ![]() ![]() Next time I'll make sure my glasses are not on upside down......LOL Ken
__________________ " I can't remember the last time I forgot something" Last edited by Blackjaxe; 02-19-2010 at 01:53 PM. |
#14
Blackjaxe, please submit the branch with bark, etc. Please don't "sit this one out". All of us can learn from everyone else. I personally would like to know how you, and everyone else, create items. Any submission may trigger off other ideas and we can all grow together. For instance, I have never used Modge Podge (submitted by Lynn), but I'm very interested in it's possiblities. Keep 'em coming folks. Happy Carving DM
#15
Mod Podge is just a cheap version of Acrylic Mat Medium. Been using it for the last 40 years.
#16
I didn't know that Mod podge is acrylic matt medium...thanks Lynn. An easy way to make a leaf (s) is to 1. fold two pieces of brown paper bag together. 2. draw one half of a leaf on the paper with the fold as the center of the leaf. 3. cut out the leaf producing two leaves that are the same. 4. use an adhesive between the leaves (I use Beacons 3 in 1 because it grabs quickly) and insert a 24 gauge wire...that has a flattened end...between the two leaves. 5. using a small ball burning pen make the veins in the leaf 6. seal the paper leaves with your favorite sealer 7. paint to suit. burn in some well placed holes (between the veins...not on a vein) and some nicks on a few edges. 8. attach the open end of the wire to your main vine or branch. Please add to this technique. Thanks DM |
#17
| "6. seal the paper leaves with your favorite sealer" Please, what's your favorite sealer? "7. paint to suit. burn in some well placed holes (between the veins...not on a vein) and some nicks on a few edges." You burn AFTER you seal and paint? Can I ask you please to explain? I have so much to learn ... thanks.
__________________ Triumph is umph added to try |
#18
Favorite sealer is Deft sanding and sealer (lacquer) and lacquer thinner 50-50 mixture. just paint it on. Or use Krylon clear spray (Walmart $2.7). About burning holes, nicks, etc in leaf, I didn't make that clear. I do the veins, burn the holes and edges prior to sealing and painting. I think any adhesive would work in gluing the two leaves together. The reason to use two leaves is to hide the stem and get it to adher well. The Beacons 3 in 1 really works rapidly so you have to put the stem in asap. Hope all of this is clear...if not please ask questions. Anyone with a different technique please jump in here. We are all learning. DM |
#19
aahhhhhhhh - Thank you. The only leaves I've made (very few)- I made from very thin brass sheets. That's easy to cut with common scissors and use my power sander to get holes anywhere. BUT I can't find a glue that is truly safe/sturdy enough for attaching the stem. Again - thank you.
#20
If you are using brass or copper I don't think glue is the answer. Soldering is much better. The following method works for me...to solder.
| Habitat? | Steve Sargent | Animal and Bird Carving | 16 | 10-03-2009 11:26 PM |
| Habitat??? | TreeWizard | General Wood Carving | 1 | 07-22-2009 06:38 PM |
| Habitat | Box Car Russell | General Wood Carving | 3 | 02-12-2009 05:23 PM |
| Habitat ? | SmallJawz | Caricature Carving | 9 | 02-21-2006 05:33 PM |
| Habitat?? | Callynne | Animal and Bird Carving | 8 | 11-10-2003 08:48 AM |
