Old 12-13-2009, 02:37 PM
Default water splashs and water using resins
I am carving a fish and want to create a habitat scene using resins to create water and splashes. I have never done this before so I don t know what products are used or where to get info on this .need help. thanks terry.
Old 12-13-2009, 02:55 PM
Mitchell's Avatar
Default Re: water splashs and water using resins
maybe something here:
How to use resin water
or here:
Water????
Both are a little old, but relevant.
My WCI gallery
CCA Website Caricature Carvers of America
Here's one source...Van Dykes Taxidermy. Check the bottom of this page for a "how to video"
Water and Ice Crystals 1/2 Lb, Habitat, Panels and Display at Van Dykes Taxidermy
Old 12-14-2009, 05:11 AM
midnightcarver's Avatar
Was going to suggest the taxidermy shop as well. They have great stuff there and almost all of their stuff comes with easy to follow directions ( they assume not everyone is an expert taxidermist) As a hobby taxidermist myself, most of the taxidermy supply stores have online shops, but they used to advertise their catalogs in the back of field and stream magazines, Or you can go to your local taxidermist and he might sell you some of his stock for cost minus shipping. Taxidermist are also a great resource to give you pointers on using the stuff. Good luck!
Home Page
Mckinzie taxidermy
Old 12-14-2009, 01:11 PM
dnstehly's Avatar
The resin material of choice for most people that I have talked to is Envirotex Lite available at craft stores such as Michael's. Its a two part mixture and very easy to work with. I too am a novice at making habitats but found it very easy to create a still water scene with this material. I have been told that splashes can be created with it by dropping it into a tall container such as a barrel. I have not experimented with that technique yet and can give you no infomation on the details of the procedure.
David
www.Artsticks.com
Old 12-14-2009, 02:18 PM
spot
Send a message via MSN to sccarnes
check out lynn doughty's site , he made a cannoe in water, and the site used to have how he did it, haven't checked for a while
sam
Hoodie On The Water ducksdown Animal and Bird Carving 10 10-26-2009 08:46 AM
Oil/water/dry sharpening xsailer Woodcarving Tools, Technology & Sharpening 14 08-08-2006 01:04 PM
I'm in a bit of hot water... MDWine Off Topic 5 05-09-2006 09:23 PM
Over water/under water relief carving Gray_Fox General Wood Carving 3 11-22-2004 06:57 AM
Water???? Jeff Wood Finishing and Painting 6 02-15-2003 03:09 PM
