Old 09-03-2008, 08:56 AM
Default Using "Ol' Faithfull"
After a near two year hiatus at the carving bench (for a whole buncha reasons) I finally cleaned up the shop a bit and got things organized enough to get back at working on a relief of the decapod steam engine that served the Ashland ore docks for years.
Stropped up the gouges, dusted off the carving, turned the overheads back on, adjusted the bench a bit and went at it. Then decided that I'd give the fixed blade utility knife a try for working on relief..............WOW, does that thing work for new stops, cleaning up corners and setting undercuts!
Anyway, I'm still a pokey carver but seem to be back on track (no pun intended) so maybe this piece will finally get finished.
Thanks for the idea on the utility knife, Lynn, and thanks to Hi Ho for sending this one along!
Old 09-03-2008, 09:42 AM
Just Carving's Avatar
WhittleBear Carver
Default Re: Using "Ol' Faithfull"
Welcome back sir!
Hope you're enjoying yourself!
Them box cutters work pretty good huh?!?!
Old 09-03-2008, 09:44 AM
Irishman's Avatar
A passion for carving
Well Al, you were away much longer than I have been so you have some catching up to do.
Patrick
Old 09-03-2008, 11:45 AM
Hi Al,
With all the postings from you, I never would have suspected you weren't carving. You've certainly got the knowledge. I'm sure you'll fall right back into it as if you'd never stopped. Looking forward to this relief.
http://stickcarving.webs.com/
My Gallery photos.
Old 09-03-2008, 12:04 PM
BRIAN D's Avatar
Al, Good to hear you got them chips a flyin! Brian D
"The Artist ".."The Craftsman".."The Woodcarver" gene-messer Caricature Carving 41 01-29-2011 08:16 PM
"Joe Boxer", "Golf-Guy" Coffeeman Caricature Carving 15 04-02-2008 10:58 PM
"Cutting Oil" vs "Honing Oil xsailer Woodcarving Tools, Technology & Sharpening 3 11-05-2006 08:37 PM
wooden "nickels" or "dogtags" Clifford_Parker Pyrography and Woodburning 13 08-27-2006 12:41 PM
carved "trout" coffee table plans needed Guest Animal and Bird Carving 4 11-14-2002 01:02 PM
