Old 10-08-2008, 05:54 PM
Default Split Mandrel sand paper??
I think I am making this too difficult however, I was watching the Frank Russell DVD and he had a pattern for cutting sandpaper for the split mandrel. Any idea where to get the pattern from? Thanks
Old 10-08-2008, 08:01 PM
Default Re: Split Mandrel sand paper??
The pattern for the paper would depend on the diameter of the mandrel. Getting the width should be simple enough...just the width of the mandrel. Length will be somewhere around 3.14 x the diameter of the mandrel + 1/2" to 3/4" to allow for the insertion into the split.
Hope this helps.
Old 10-08-2008, 09:27 PM
I have the pattern but it is at work. I won't be at work until the 13th. If you haven't found the pattern by then let me know and I'll scan it for you.
Steve
www.birkes.com
Old 10-10-2008, 02:49 PM
Dull Knife
I have a split mandrel for sand paper, probably not the one you're talking about..... my problem is I can't seem to roll the paper tight enough to get it to stay on the mandrel after I've glued the end on to the roll??
Last edited by Dull Knife; 10-10-2008 at 02:52 PM. Reason: for got to add a few words.....dah??
Old 10-10-2008, 04:47 PM
I think Frank Russell indicated to use cloth backed sand paper instead of paper backed if I remember correctly, just a thought.
Old 10-10-2008, 05:33 PM
Kringle Addict
Hi Ken,
I hope you got the pm about the source for cloth backed sandpaper..... Yes, cloth backed is the only thing to use. I buy mine by the roll through the Hummul Flier out of Penn. They have corse on up to very fine grits. I buy a lot of my bits through them too.
Dull Knife,
Some times the roll of cloth will not fit snug enough to stay on the mandrel when in constant use. I usually run into that when I am removing the bit from the handpiece because you pretty much have to grab it by the sandpaper to pull it off and guess what? Off the mandrel it comes.... so I take a tiny drop of super glue, dab it on the mandrel and shove the sandpaper back on. After a few seconds, it's ready to go again. The only thing is when you are ready to take the old paper off and put new on, you might have to soak it in acetone for a little bit to get the old one off.
http://susanmattix.com
Old 10-11-2008, 12:14 PM
Dull Knife
Originally Posted by susieq View Post
Hi Ken,
Dull Knife,
Aha....so that's the secret. (cloth backed sand paper). The mandrel that I have was from a lady carver, and she used the yellow sand paper.
I've basicly given up on using this type of sanding...it takes too long to get it ready to use and then it doesn't last all that long any hoo....that is, of course, if I could get it to work in the first place. Thankx for the info.
Split mandrel Sandpaper? foamer01 Power Carving 1 10-10-2008 09:18 AM
split face kenns2 General Wood Carving 8 07-03-2008 02:31 PM
Back From The Sand Box WOODIE13 Off Topic 24 11-13-2007 09:42 PM
dogwood split 4" log Thomp Carving Wood & Materials 2 12-19-2006 03:07 AM
Sand Sculpture Newgouger Carving Wood & Materials 4 09-02-2003 07:24 AM
