Old 11-06-2011, 08:20 PM
Default roughout machine
I am new to carving, however I've found a niche in my area to sell santas and other ornaments. I can not imagine the time it would take do them all with only the eleven hand tools I own. The carvings are of my own creation but would like advice on duplicating them. Thinking around ten different roughouts with 30 units of each. I have two small children and a full time job otherwise. Any way to save time is valueable. I am considering this as a jumping off point for the transition into a new job. Wood Carving for a LIving!!
Old 11-07-2011, 09:36 PM
Scott Hagerty's Avatar
Default Re: roughout machine
You could contact one of the companies that makes roughouts and check into what it would take for them to duplicate your carvings. One other option would be to purchase a duplicator and do your own.
Old 11-08-2011, 04:01 PM
brianrickman's Avatar
You can remove a lot of wood in a hurry with a band saw. If the shape of your carvings is relatively simple, this may be enough of a time saver to make your task viable. It is certainly much less expensive then a duplicating machine.
Old 11-08-2011, 05:03 PM
Donsexton's Avatar
The pro CNC machine has a big upfront cost but it will get the job done it doesn’t get tired. When I was working in India they had whole streets with workshops on both sides that did production carvings. When I was working in the Philippines they had whole villages that did production carvings. I bet you could find an agent in India that would do production carving on your rough outs then you put your finishing touches and make it yours. The big Dupla-Carvers that high end furniture manufactures use here in this country are very expensive as well but would do the job you want. I would think as stated by another member a band saw would be the most economical.
Old 11-08-2011, 06:55 PM
Gulf Coast Handyman's Avatar
Here are some, DUPLI-CARVERS-Wood Carvers Supply
Dave
Old 11-08-2011, 09:19 PM
I do not know what kind of carving you are doing, but is a way I read about to do animals.
I just took some photos of the book.
Old 11-08-2011, 09:46 PM
Fit, that's a good find! Who'da ever thunk it!
Old 11-08-2011, 10:43 PM
I got that from the book, the WoodWright Shop. By Roy Underhill. His PBS show is what got me in to carving.
Old 11-09-2011, 07:07 AM
Thanks for all the input. I have a bandsaw, Delta table top, and it does help. I think I will wait to buy a duplicator untill I've already made enough money carving to pay for it. Start small right
Old 11-09-2011, 09:10 AM
Hope it all works out for you, good luck!
GENE the machine therandallknight Caricature Carving 3 11-21-2009 09:43 PM
carving machine Robbie General Wood Carving 3 11-11-2009 10:15 AM
Limberjack machine mpounders General Wood Carving 16 07-20-2009 12:37 PM
New to machine carving skiptamm Welcome Members 7 12-09-2007 04:52 PM
The Shop (decoycarves roughout machine) Goody Woodcarving Tools, Technology & Sharpening 6 05-31-2005 01:20 PM
