General Wood Carving | |||
I have been wanting to try a recip carving tool for larger projects. Does anyone have any recomendations on these tools? Do you like them? Thanks Whiskers |
WeCheers has one at Approximately $150.00. Have heard some carvers don't like it but have seen and heard those who do. Do a Google on WeCheers Reciprocating carver. Then one for Foredom. Definitely the foredam is higher in price, then you have to but the different hand pieces. I don't own one but have used both at shows. Both cuts great.
Whiskers, I wouldnt be without mine I have various reciprocating carvers and let me give you my opinion on the ones I have. Mind you this is just my opinion this is just my take on them. I have an Arbortech that is a wood hog very powerful and removes a lot of wood fast. Its down fall is that there are only a few profiles in the gouges that it takes. I also have a Skil unfortunatly they dont make it anymore. Went off the market last year I was lucky enough to pick up three of them. It takes the flexcut gouges and is probably my favorite of all of the reciprocators because it has three speeds. Proxxon have a great little machine that also takes the Flexcut gouges I find it a little underpowered for me but then again I do very big carvings. Weecher also make an inexpensive reciprocator I dont have one but have heard nothing bad about them. Flexcut have just released their new reciprocator havent heard any reports on it only that it is very expensive, almost $600 US. Automach also make a great machine again I dont have one but I have used one. It is a Japanese made product very powerful but again it has a very limited tool profile. Hope this has helped I know there are more of them out there but these are the ones I am familier with. Colin |
I have the Ryobi that takes the flexcut chisels....if works fine...not a real power house...but with flexcut, if you get too carried away, you chip the blades anyway....I just want to get the bulk off and finish by hand....guess I am turning into a neanderthal! :P ( my wife says 'guess'..'turning' lol)
Whiskers, I use the automach which I've seen sell between 250.00 and 300.00....it works great but you have to loosen the collar and grease the bearing periodicaly depending on how much you use it. They seem to last forever. Colin, you mentioned it has limited blades...the flexcut blades have shims that allows you yo use them in the automach. My other favorite is the Ryobi which unfortunatly is no longer made...you can often find new or used ones on Ebay. They also can be used with the flexcut blades. greg |
I have the Welcher It does a good job ideal for removing a lot of wood fast I just use the gougs that came with it have not needed any more I use the rotary handpiece all the time I also have a Dremel that i use all the time The Welcher is a good buy for the money comes with flex shaft and rotary and reciprocating hand pieces I use the rotary handpiece a lot and different burrs in it i also use my dremel about as much keep my dremel set up with the sanding disc most of the time |
I've got one of those 'high quality' Tiwanese Ryobi knockoffs I bought from the Cummins tool truck sale for $19.99. It even came with the Ryobi tips. I've only played with it a little but it seems OK. It does get a little on the warm side, you have to hold it just right so the air doesn't blow out the vents on your hand and make sure your fingers aren't touching the the brush caps. I like hand carving but also like toys, so for 20 bucks it was something new to play with ![]() Would I buy one of those fancy expensive carvers - Nope! To me the expense isn't worth it cause I wouldn't use it. Same reason I won't buy a Foredom or other expensive flex-shaft, I'vre got an old Dremel I've had for years and also bought one of those Harbor Freight $49.99 flex-shafts, and don't use them much either! |
Randy I have to agree with you about the Cummins, not bad for the price. I had the opportunity to try the Foredom powercarver at Lowes; (our local Lowes began carrying certain namebrand carving supplies). I was impressed with the Foredom, however there is no way I could ever justify spending 250 bucks on myself. I'd love one but 'ain't gonna happen'. I was happy to see the Lowe's carving selection but highly disappointed in the pricing.
__________________ Humor Heals and when spread can be infectious. |
'I've got one of those 'high quality' Tiwanese Ryobi knockoffs I bought from the Cummins tool truck sale for $19.99.' Randy, I tried one too...their fine for OCCASIONAL use...if you use it alot they poop out in about 2 months Â*> |
Well, mine ought to last about forever. I've had it 3 or 4 months and used it about 10-15 minutes the first day. Maybe when I get caughtup I'll pull it out and play with it some more for a few minutes |
| Looking for a Skil 1910 Reciprocating Carver | Colin-Partridge | General Wood Carving | 0 | 07-15-2006 01:40 PM |
| Proxxon Power Carver | MelNM | Woodcarving Tools, Technology & Sharpening | 6 | 01-26-2006 06:47 PM |
| Flexsteel Power carver | MelNM | General Wood Carving | 6 | 01-17-2005 02:00 PM |
| Reciprocating carver | BobD | Woodcarving Tools, Technology & Sharpening | 10 | 10-11-2004 11:11 AM |
| looking for a Skil power carver | Colin-Partridge | Woodcarving Tools, Technology & Sharpening | 1 | 02-07-2003 07:13 AM |
