General Wood Carving | |||
Hey Everybody, I have a question I'm hoping someone might have the answer to regarding drying wood. Here's the question: Is there a way to properly dry wood so that the bark doesn't come off the piece? Here's the situation: I take a branch about 3" in diameter and cut out 1/4" disks with my bandsaw. I then drill a hole at the top and let them dry. Once they dry, I paint a picture on the disk, add some twine, and they become rustic Christmas ornaments. Here's the problem: During the drying stage, the wood shrinks, causing the bark to detach and in most cases, break off. Since I haven't been able to figure out how to correct this, I bought a bunch of pretreated disks. This not only was waaaay too expensive, but the company really takes advantage in that out of the bunch (100 disks), only a few were a good size (2 1/2"-3"). The rest are like 1" in diameter, not a whole lot I could do with them. ![]() It seems a shame that I live on a wooded lot, with tons of branches, my own bandsaw, but I'm resorting to buying bandsawed disks! Can anyone offer suggestions? Maybe I'm using the wrong type of wood? Or maybe instead of cutting straight down, should I cut on a slight angle? I've tried Googling this many times, but can't find any information anywhere. Please send along anything thoughts. I'm really at a loss! Thank you, Jillsy |
thats a very cool tip makinchips. i learn something new every daySmile would that work in reverse to if you want to remove the bark as easy as possiable would spring or summer be the best time
Thank you makingchips! Does it matter the type of tree branch I use? Is it ok to cut it straight or on an angle? (I prefer just cutting it straight up and down) Would it be ok if I dried them in a food dehydrator in order to do it quicker? Should I use a healthy branch, right off the tree, or can I use one that's fallen to the ground? Last edited by jillsy; 05-05-2008 at 06:11 PM. |
Thanks Joe! Looks like I have a long wait to be able to try this, but I'm really looking forward to it. In the meantime, I guess I'll practice on these itsy-bitsy little disks. Appreciate your help, Jillsy |
| A question on drying | Dundee | Carving Wood & Materials | 5 | 04-21-2008 10:13 AM |
| Drying Frozen Stick Question. | Skulli | Carving Wood & Materials | 9 | 10-31-2006 07:56 AM |
| Drying wood | missquacks | Carving Wood & Materials | 6 | 10-23-2006 07:26 PM |
| Drying wood | carver6 | Carving Wood & Materials | 11 | 01-15-2005 12:15 PM |
| Drying wood | Saturno10 | Carving Wood & Materials | 3 | 05-04-2003 09:31 PM |
