Old 01-18-2010, 05:20 AM
Smile Power carvng hiking sticks
Can I rough out a wood spirit or caricature head on a cane or hiking stick about 1 1/2 or 3/4 inch diameter hardwood with a micro-motor without undue wear or damage to the micro-motor. I was planning on using a 1/4 - 5/16 typhoon bur and a foredom 1070 micro-motor. I was planning on doing mostly small carving with the micro-motor. 1 1/2 to 1 3/4 stock would be as large as I would do.
Thanks,
Paul
Old 01-18-2010, 07:34 PM
Default Re: Power carvng hiking sticks
Hi Paul,
I don't see why you can't do exactly what you said with your micro-motor. The only problem you will encounter is how aggressive you want to get. If you take it easy and don't push too hard you won't overwork or overheat the motor. I use a Wecheer detail engraver/micromotor and have no problems with it on my sticks.
http://stickcarving.webs.com/
My Gallery photos.
Old 01-18-2010, 10:51 PM
SeaLeveler's Avatar
Shouldn't be a problem.Just let the speed do the work and not put a strain on the motor.Tony
a couple of new hiking sticks DADDIO Stick and Cane Carving 26 07-14-2009 11:24 PM
Hiking Stick Curtscarving Stick and Cane Carving 15 03-30-2009 06:35 PM
A few hiking sticks GAcarver Stick and Cane Carving 11 01-24-2009 07:47 PM
Hiking Staff Irishman General Wood Carving 31 10-17-2008 11:06 AM
Hiking Sticks? Jon Harl Carving Wood & Materials 1 01-24-2006 05:26 PM
