Old 03-12-2008, 02:00 PM
Question Need small round over bit
Help,I need a small round over cutter bit-preferably 1/16 radius that has a pointed end(no pilot). I called dremel and no luck. Does anyone know if Weecher or Foredom has this cutter? I am trying to cut some stamens(?) or buds in the center of a flower. Any other cutter shape cuts into the adjacent bud. Don't know how to get there ? Can use any help. pandb12167@aol.com thanks.pw
Old 03-12-2008, 03:24 PM
Skip
Send a message via AIM to achaundy
Default Re: Need small round over bit
Maby you could try making your own from another Dremel bit, shouldn't be much grinding. Skip
Mobster A.Chaundy
I am always doing that which I cannot do, in order that I may learn how to do it.
Old 03-12-2008, 05:38 PM
Smile Re: Need small round over bit
Thanks achaundy,I may have to try make one. Now if I could just remember how to form a grinding stone radius......pw
Old 03-12-2008, 06:02 PM
Skip
Normally you would use a silicon carbide dressing stone. Surely you could buy a Dremel type grinding bit with a close enough radius. Skip
Mobster A.Chaundy
Old 03-12-2008, 07:26 PM
I've looked,but nothing close. I maybe going about this wrong,maybe I should buy a 1/8 stone and grind the radius in another type of cutter. What do you think??pw
Old 03-12-2008, 07:57 PM
Skip
Ah Ha now your getting it I knew you would. Skip
Mobster A.Chaundy
Old 03-12-2008, 08:25 PM
I'll give it a go,nothing to lose since I can't buy one. I guess most people just hand carve with a gouge(roundit around ha ha),but I'm not that porficient. thks,pw
Old 03-24-2008, 04:39 PM
Have you tried using a reglar drill bit and just hack it to a usable length and a little grinding for shape? ONCE
Old 03-24-2008, 04:47 PM
Have you tried using a regular drill bit? Just hack it to a usable length and use a little grinding for shape. I've used small broken drill bits to clean loose matrix out of cracks in fossils.
Old 03-24-2008, 07:12 PM
Thanks fop.. I had not considered that,but it sounds like a good idea. I may give it a try. Thks,have a great day. If you will pm me,I'll show you a set up I devised for a Mill-route. Its mainly a sign carving machine,but I mounted a dremel on the front and will try to carve a tudor rose tomorrow. pwMotorcycle
First In-The-Round kcwaterguy New Projects and Works in Progress (WIP) 9 09-01-2006 08:16 AM
round?? Alice in Wonderland Wood Carving Tips and Techniques 7 01-20-2006 06:09 PM
Santa in the round. Mark Gargac New Projects and Works in Progress (WIP) 10 11-13-2005 08:21 PM
Santa in the round Mark Gargac New Projects and Works in Progress (WIP) 0 11-11-2005 10:51 PM
My first in the round Ashbys Wood Carving for Beginners 21 07-20-2005 02:46 PM
