Old 07-27-2007, 06:58 PM
chuckt's Avatar
plain ol' member
Default Re: Need a Portable "bench"
The thing I liked about my Harbor Freight table - adjustable height, tilt top, fairly heavy, I could always add a different top at a later date, clamping capability built in.
If I need to weight it down I have a couple options - 1. Add a shelf across the bottom supports and place weight on that. 2. Add a plywood floor underneath and attach the bottom of the legs to it via angle iron and bolts. Then my own weight standing or sitting on it becomes the stability required. 3. Simply step on the bottom cross supports temporarily.
Check it out here -> http://www.harborfreight.com/cpi/cta...emnumber=94214
$30 is hard to beat.
ChuckT
Old 07-27-2007, 07:13 PM
chuckt's Avatar
plain ol' member
Originally Posted by Tom H
Jim, The key phrase in your request for a portable bench is the need to mount a vise. This means that you will want a heavier bench than I use. I think you'll need a heavier bench than the Workmate too.
Hmm - I think that depends on what he means by vise. If you mean your typical workshop bench vise (like the quick release Record style shouder or tail vise) then no - the workmate won't work.
If he means a work positioner like the Panavise or similar work holding devises then that should be no problem. I intend to do so on mine eventually. Maybe even mount a carving arm, and a stick holding jig for carving hiking/walking sticks.
Just a thought.
ChuckT
Old 07-27-2007, 08:57 PM
Whimsy_Carver's Avatar
Thanks, Paul, HiHo, Tom, Russell, Chuck, Thor and others for the very helpful info. You guys make this a great listserv.
Jim
"Joe Boxer", "Golf-Guy" Coffeeman Caricature Carving 15 04-02-2008 10:58 PM
A Question on "Bench Knives" AlArchie Wood Carving for Beginners 7 07-27-2007 11:13 AM
"Cutting Oil" vs "Honing Oil xsailer Woodcarving Tools, Technology & Sharpening 3 11-05-2006 08:37 PM
wooden "nickels" or "dogtags" Clifford_Parker Pyrography and Woodburning 13 08-27-2006 12:41 PM
PFEIL "Swiss Made" Brienz Carver's Knife BasketballJones Woodcarving Tools, Technology & Sharpening 5 09-14-2004 07:47 AM
