Old 01-16-2002, 08:20 AM
MikeD
Guest
Posts: n/a
Default Inside the letters & frame - Questions
Hi,
I decided for a first project to make a set of ABC childs blocks. I have a question about A, K, M, etc. What is the best method of getting the wood out inside the triangle of the letter?
Secondly, I decided a small frame on the outside of the block would be nice. I am going aroind the edge placing vertical cuts so I won't cut into the frame area. Is this the correct way to do it, or is there a better way?
FWIW, after hitting the letter C, I know this is definately a quick learning project - lot's of fun though! I imagine by the time I hit Z, and get some simple patterns on the sides, I will see some improvement. At the very worst, I will have a store of knowledge on how not to do it.
Thanks in advance for your replies.
Mike
Old 01-16-2002, 11:51 AM
Captain_Bandaid's Avatar
Default Re: Inside the letters & frame - Questions
Well, a skew chisel would work if there is room for it. I have gotten quite lazy lately and found that my Dremmel tool makes a fine router. With the router attachment and a 1/8' or 1/16' fluted bit (including flutes on the BOTTOM of the bit), I can clean up edges and corners very quickly and neatly. It also helps to maintain a consistant depth of cut and ensure the edges are flat and vertical. Or if you insist, a razor knife and a magnifying glass would probably do the job. Good Luck!
Captain Bandaid
Old 01-17-2002, 08:59 PM
Guest
Guest
Posts: n/a
Flexcut makes a set of tools called 'Micro' something. They are very good for those tight spots, but I think they cost about $60.00 for the set of 4. If the triangle is not too large, you could project the cuts for the sides of the space down to a point, removing a small pyramid like the chip carvers do.
Good Luck...
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f38/inside-letters-and-frame-questions-4633/
General Wood Carving [Archive] - Page 44 - Woodcarving Illustrated Message Board This thread Refback 02-27-2008 12:08 PM
painting incised letters John Wood Carving for Beginners 6 02-24-2007 08:15 AM
Need help on a picture frame. Urbancowboy88 New Projects and Works in Progress (WIP) 4 05-05-2006 10:38 AM
Carving Letters TomHoffman Wood Carving for Beginners 11 12-03-2005 01:46 PM
Relief carving on mirror frame Dan C Wood Carving for Beginners 5 10-30-2005 10:40 PM
Oval Picture Frame whittlinwit General Wood Carving 7 06-02-2003 08:05 PM
