General Wood Carving | |||
I have a piece of driftwood that will be used indoors when completed.After it dries and has been cleaned, what should I use to seal the wood not sure what to use? On the final finish I plan on useing a clear satin,any suggestions. Bill V |
I use clear Cabot sanding sealer...it not only seals but reinforces any deteriorating fibers. This stuff will soak into driftwood so it may take several treatments. Minwax or Ace would probably work as well. Use the oil based, not the water based. Al Last edited by AlArchie; 10-21-2009 at 10:17 AM. |
| Thanks for the reply Al. I picked up the Cabot sand and sealer today,it worked just fine. Bill V |
Melted beeswax with walnut or veggie oils makes a nice finish for inside carvings. Smells good too!
__________________ My Gallery- http://www.woodcarvingillustrated.co...on-of-the-dell My etsy store- http://www.etsy.com/shop/Woodforddel...f=pr_shop_more |
| driftwood | Ron James | Carving in Found Wood | 5 | 09-13-2009 01:17 PM |
| Driftwood | Dan Wegiel | Carving in Found Wood | 18 | 07-08-2009 12:38 AM |
| driftwood Elk | tnartist05 | General Wood Carving | 17 | 03-31-2008 08:00 PM |
| Driftwood | Gooch | Welcome Members | 1 | 06-06-2007 06:40 PM |
| Driftwood? | Dogfish | Carving Wood & Materials | 14 | 08-18-2006 06:49 AM |
