Old 07-12-2011, 08:38 AM
Howie's Avatar
Default Heat crack in wood
Howdy folks,
In lovely Southern Ontario, it was 38 degrees with humidity yesterday. I brought my shark (WIP) with me to the office to get some photos done. I noticed some small tool marks on the side and made a mental note to try and sand them out.
After work I picked up my wife and stopped at the drug store on the way home. That's when I noticed those little tool marks looked like .5mm cracks. By the time we got home, they were even more significant.
But then, an hour later, they were back to being small tool marks. I guess the extreme heat/humidity caused the wood to expand a bit and split. A friend suggested I allow it to expand a bit again and use a syringe to inject some wood glue into the cracks, so that when it contracts, it'll be fully healed.
Anyone have this issue before?
Thanks,
-Howie
___
My Etsy store (Dogwood Carvings)
Old 07-12-2011, 09:15 AM
Gulf Coast Handyman's Avatar
Default Re: Heat crack in wood
Never had that happen Howie, and we have HIGH humidity here in Florida. I like the glue idea, seems like it would help. Might also cause a larger crack if you don't allow for for expansion???
Dave
Old 07-12-2011, 09:52 AM
carvingbarn's Avatar
Howie if wood has not dried well before you carve it can and often will check or crack with change in temp and humidity. A sudden change to drier heated air of your office may have brought it about. Oil finishes can help with checking. I have thought wood was dry and got in to it an inch or so to find the moisture levels are still high. I set it back and wait a few more months. You can also use product like Peg.
Randy
May your neighbors respect you, Trouble neglect you, The angels protect you, And heaven accept you.
Old 07-12-2011, 10:03 AM
twymanok's Avatar
I have taken wood glue that dries clear rubbed it in the cracks then sanded it with 220 grit while the glue is still wet.
Matt
Celebrate Small Victories for What They are- Victories
Heat Treating Info. Gulf Coast Handyman Woodcarving Tools, Technology & Sharpening 7 06-11-2011 09:27 AM
Understanding the heat at the tip...with tension... traditional-toolworks Chainsaw Carving 13 11-03-2009 05:22 AM
Help! Wood least likely to crack? tree-ni Chainsaw Carving 7 01-24-2009 01:17 PM
Heat is Brutal Kenny_S Off Topic 5 07-17-2006 08:18 PM
Heat Transfer Patterns Guest Relief and Chip Carving 7 02-22-2003 11:10 PM
